nicho
RIP
What do you need a coat for - harden up man, it’s not necessary!Isn't a bow thruster a crutch for the hard of manoeuvring?
I'll get me coat!
I'll get me coat!
I wouldn't go so far, but from my own observations, much of it in Continental locks, there is quite a high proportion of boat owners who can't handle their boats even with a bow thruster. The temptation is there for those with limited experience to acquire boats that are outside their normal range of competence on the basis that a bow thruster will make them more manageable. It was certainly the case with the two owners I mentioned above that they tended to become more careless when they had thrusters available to them.Why do people presume that anyone using a bow thruster can't handle a yacht without one? That seems a bit daft to me.
Well I can happily say that a combination of bow thruster and suitable use of engine will enable me to turn our 41.5 foot boat in very nearly its own length through over 180 degrees or more in one continuous controlled movement and at slow speed.
Like to see you do that without one but it just does not happen in my boat! …
Er only if turning the bow away from any strong breeze. At least with mine.Turning a yacht 180 in its own length, without a bow thruster, is very easy to do. I have done this with numerous sailing boats, hull types. It was / is taught by sailing schools. It does have limitations, such as only being able to turn in the direction opposite to prop walk.
A bow thruster is a great aid, both for the boat user and neighbours. However, learn how to use it. I have seen a few manoeuvres over the years where clearly the user did not understand the forces on the boat as they berthed (with or without a bow thruster).
Have you ever tried going out astern up to somewhere near the middle of your yellow arrow, then going ahead to the entrance?Oh and the red green lines on my pictures just represent the way the boat is turning and to try and show a common route out of the berth. They do not necessarily indicate wheel/rudder position.
I do know that with the wheel turned fully to port, with judicious use of forward and reverse power, I can turn on the spot.
With a bit of wind pushing the bow off, it doesn't happen... and well, ending up all the way back down the fairway and warping off is always a last resort.
Bow thrusters in themselves I do not care, each to his own, but I definitely hate bow thruster users who leave at 0600 in the morning in perfectly windless and tideless moments and must absolutely use their BT port-starboard-port-starboard-port-starboard-port-starboard-port-starboard to perfectly align their boat centerline to a 1° tolerance before leaving an otherwise empty pontoon or even anchorage, meanwhile waking up everyone who is sleeping onboard in a 50m range.I don’t see why they are so hated
Just a thought.
It does annoy me to see a motorboat with two engines boat entering a marina fairway, then steering it just using the bowthruster. With any forward motion, a thruster loses considerable turning power, so all you can hear is the noise of it constantly being used to keep the boat in a straight line. Grrrr! (but then why should it matter)
