guardian
Just found this if anyone's interested in heating water using their Chinesium heater:
2KW system
5KW system
2KW system
5KW system
There is a chinese heater with a built in water heating system !Just found this if anyone's interested in heating water using their Chinesium heater:
As I started this thread back in 2019 I feel I should post this update. A 5kw unit, I fitted it in the stern with four outlets, stern cabin, saloon, heads and forecabin and so far been pleased. I did look at the facebook site about chinese heaters and it seems that most of the problems appear to be poor installations. Improvements I did as follows:- hose clips are crap so I used JCS HiGrip SS clips; upgraded the power cable from battery to heater; used eberspacher hull outlet and exhaust pipe; fitted high temperature insulation to the exhaust and silencer secured with stainless cable ties; fitted an adjustable divertor at the stern outlet as cabin got far too hot; used flexible aluminium ducting insulated with armaflex insulation; stern and saloon at 75mm and 60mm for heads and forecabin; replaced nylon fuel tubing with copper tubing as tubing going through stern cabin - essential for inland waterways but I played safe; did not use supplied fuel tank as could not find a suitable place so took fuel from main diesel tank; replaced fuel hose clips with stainless steel clips. The controller supplied was simple, just ON/OFF button and UP/DOWN buttons + display - I deliberately chose this controller as the more complicated ones seem to give users a lot of grief.
Initially it took several minutes to get fuel to the heater but it is a long way.
The total cost was over £400 so considerably cheaper than using Eber/Webasto heater. I intend to fit an ON/OFF switch on the power supply as display is always on when heater not used. The most difficult part of the installation was fitting the ducting.
It has worked perfectly every time I've used it so am quite happy with the heater and my installation.
I had exactly the same. Took a fair while to figure out what was wrong.My 3kw unit came set for 24v operation
If %anyone finds a uk seller selling the air and water heater please post a link
Hi. I'm interested in one of these (the air heater not the air/water). Where did you exhaust and how noisy are they? That is, will there be frowns in the marina in the morning? Thanks!As I started this thread back in 2019 I feel I should post this update. A 5kw unit, I fitted it in the stern with four outlets, stern cabin, saloon, heads and forecabin and so far been pleased. I did look at the facebook site about chinese heaters and it seems that most of the problems appear to be poor installations. Improvements I did as follows:- hose clips are crap so I used JCS HiGrip SS clips; upgraded the power cable from battery to heater; used eberspacher hull outlet and exhaust pipe; fitted high temperature insulation to the exhaust and silencer secured with stainless cable ties; fitted an adjustable divertor at the stern outlet as cabin got far too hot; used flexible aluminium ducting insulated with armaflex insulation; stern and saloon at 75mm and 60mm for heads and forecabin; replaced nylon fuel tubing with copper tubing as tubing going through stern cabin - essential for inland waterways but I played safe; did not use supplied fuel tank as could not find a suitable place so took fuel from main diesel tank; replaced fuel hose clips with stainless steel clips. The controller supplied was simple, just ON/OFF button and UP/DOWN buttons + display - I deliberately chose this controller as the more complicated ones seem to give users a lot of grief.
A real problem! I have two - the one in the stern cabin exhausts through the transom which is fine as it impacts on nothing. However, it doesn't like a stern wind.Hi. I'm interested in one of these (the air heater not the air/water). Where did you exhaust and how noisy are they? That is, will there be frowns in the marina in the morning? Thanks!
I see two issues here, firstly what smoke? If yours is smoking them something may be wrong..Pump it downwards into the oggin? Smoke coming from the pedestal could arouse concerns!
Which one?Thanks for the advice. Bought one! Arrived today. Set it up in the shed and works a treat.
