Kelpie
@Superheat6K
Where did you get your duct tee pieces from?
With greatest respect to Owen Cox, he is importing and selling a different make of heater entirely, so has a clear commercial vested interest here, and if he is making such suggestions he should provide accurate details of such incidents, not just hearsay comments. So far I have not seen this from Owen, nor anyone else, but would welcome referrals to such incidents so I can correct my own statement.
My own statement was based upon the very active Facebook group and comments I have observed going back a year or so now, where as you yourself note NIL reports of units catching fire, yet.
from here:My son Owen, who is MD of Planar Heaters UK, has problems with a wide variety of heaters referred to him via his Q&A facebook page. He knows of a good number that have burst into flames, plus they are very noisy and the glowplugs are unreliable.
from here:Frankly, it's pure stupidity to be blindly fitting these heaters to boats. I have previously posted about one that caught fire during bench testing, but the greed of people meant that they just ignored that. I hope that when their boat does catch fire it's in an anchorage away from other boats, no-one gets hurt and their insurance refuses to pay out.
from here:Oh, wait, i do know one person that did some proper testing............. the heater caught fire![]()
Thanks for clarifying your comment. Despite some searching I too haven't found a specific comment from Owen. However, I have also asked the specific question on the Facebook Group today of any specific circumstances of these heaters catching fire. If anyone does report specifics of an actual fire, and not hearsay comments, I will make it my duty to come back here and say so.As you asked for referrals, I went back and looked for them.
I may have been wrong that the quote came direct from Owen. Looking back, it appears that it came via his dad:
from here:
http://www.ybw.com/forums/showthread.php?510405-Banggood-Diesel-Heater
In the process of looking for the thread, I did come across a couple of quotes from another Forumite with reports of fires, which may remove the 'dealer of alternative heaters' point:
from here:
http://www.ybw.com/forums/showthread.php?492470-Chinese-(5kw-)air-heater/page8
from here:
http://www.ybw.com/forums/showthread.php?492470-Chinese-(5kw-)air-heater/page10
Anyway, I have a Chinaspacher, as well as an Eber, and I am happy with both. So far I haven't experienced any fires!
The 4 way Tee ...@Superheat6K
I removed the inner clear plastic flap thingy from the lid and drilled it out to suit a metal electrical gland into which I inserted a piece of the supplied rubber tube, then on the inner side a piece of the supplied fuel pipe cut to just reach the bottom of the tank, and outside the filter then a short piece of the tube then the pipe to the tick tick pump. I did drill a tiny vent hole outside the diameter of the new gland fitting. My tank is mounted snug against a flat bulkhead in a large floor locker, using elastic straps to hold it in place, so simple to remove to refill, or to check the fuel level.@Superheat
Thanks very much for that list- really comprehensive! I used the same semi-rigid metal ducting, and a slightly cheaper exhaust skin fitting which uses allen head bolts.
I'm also thinking of fitting the fuel pipe into the lid of the tank... but I'm quite tempted to continue using my jerry can, and just buy a second cap for it.
Er - certainly NOT critical of you.Just seen your posts on the Facebook group. You have been a bit critical of me. On this thread you said there have been no reports of fires. I simply pointed out that there have been, and gave you link to two posters who claim to have heard about fires. Whether these are true or not is not for me to say, but they are clearly 'reports' so have to be acknowledge as such.
I happen to have one of these Chinese heaters and am very happy with it, but I am mindful that they will not have gone through any kind of rigorous testing, or been built to meet high EU or other standards and therefore it is possible that if they fail, they may not fail safe. I don't really understand why you are so defensive of the position you take. If you are happy, carry on, but don't dismiss reports just because you don't want to hear them. By all means take it up with the posters who made the claims, if you are that concerned about their accuracy, but don't get stroppy about me correcting your inaccurate claim that there have been no reports of fires.
I have had the rumour of a failure details confirmed, but not substantiated. I said I would come back here if I became aware of an issue. This is what has been described to me on FB group.
Apparently a couple of years ago, an independent installer, reported verbally to another dealer that he had a Chinese unit set alight when undertaking a bench test where the inlet was obstructed. The unit apparently did not stop on overheat failure, as should have happened. However, there has been no photos, nor other written account, and I have heard this secondhand.
I will be undertaking this test on the unit just installed on my boat in its installed position this weekend. I will have a bucket of water and fire extinguisher nearby. I will return to this thread to report how the test proceeds.
Beware overheat tests - I bxggered up the Ecu on my eber when the hot air outlet was dislodged, which blocked it. It did turn off, but the Ecu was toast and I bought another for over £200. It's a known cause of damaging the Ecu on Ebers - not sure if it's the same for inlet blockages...and of course no idea on our chinese imports.I have had the rumour of a failure details confirmed, but not substantiated. I said I would come back here if I became aware of an issue. This is what has been described to me on FB group.
I would rather find out it will stop in it's normal place and mode of operation under an observed test than find out the hardest way that the protection doesn't work.Would it not be prudent not to do this on your boat EEk!!!
Somebody posted a photo ( on that facebook page) of a 'Chinese ' fuel pump that had been installed under his vehicle for 12 months it looked like it was rusted almost through.They seem pretty good. Not much to them really.
each to their own,
but ill be putting a genuine Eberspacher unit in my boat.
I like to save money but I never cheap out on safety, sure it may be a low risk, but its still a risk.
so many variables, China like to save a buck, so who knows what they've cheaped out on, and how well these last in a marine environment.
Would be interesting to see a proper tear down and testing of certain failure conditions on these Chinese units though.
Yes, some proper tests would be great but there is a massive variety of these 'Chinese' units from different manufacturers and components are not compatible.
I found it difficult to determine the actual manufacturers or which specific model they made.
