burgundyben
Perhaps easier to cast a new keel?
I would check what the existing studs are made from before replacing them. If mild steel replace like with like as crevice corrosion can cause problems with stainless.Suggest you use a marine quality stainless steel for the studs and when fitted on the boat you encapsulate them so that the bilge water is kept out of the threaded part.
I would think it unlikely that they will be cast in with a j head. Studs were far more common in the industry. Thread depth for keel studs should be a minimum of
3 x the diameter.
The OP says they are cast in J shaped studs.
A question for Vyv Cox. As studding is generally available in mild steel, bright zinc plated, would you use that or insist on un-plated steel?
I cannot think of any reason why not, except that the zinc plated stuff will undoubtedly be mild and therefore the weakest available. Black steel may well be stronger, although strength is rarely an issue I think. The vast majority of boats nowadays have stainless steel keel bolts, I suspect so that it is always possible to withdraw them, unlike steel ones which could rust in to the keel.
As with all bolts, no matter the material, they rely on being dry in situ. The sealant applied before bedding is critical.
For bedding i would use a polysulphide mastic, on my first boat we used 6 tubes of boatlife then watched at least three of them squidge out as the joint was pulled up. Sadly boatlife is no longer available.
When the joint is pulled I would aim for a gasket around 3-4mm thick left, so place some rubber spacer pieces of this thickness in a few positions around the top surface of the keel, and the spread a generous layer of mastic right around these to prevent you pulling the joint up too much that too much mastic gets squeezed out. Pull up with a light firmness then allow several days for the mastic to cure. Check with the mastic makers that it will set in this situation.
The only issue with dissimilar metals is keeping the water out. The vast majority of boats use 300 series stainless steel keel bolts, although I am not certain that it is 316, or even if that is strictly necessary. I would screw them into the keel using a sealant, rather than an adhesive, in case they ever need to be withdrawn again. When refitting the keel to the boat use plenty of sealant to cover the keel surface and provide a water-tight joint. I cannot advise the best sealant for this as I suspect it is quite specialised, I would consult with someone who does it frequently.
