prv
is it any good?
Don't know that specific model, but it looks like a typical early 90s VHF. Not DSC obviously, but could very well be perfectly acceptable for voice use and will have much greater range than a handheld. If you're thinking of keeping it, the condition of the aerial system is what you need to check - it's just as important for good operation as the radio unit itself, and a lot more vulnerable to weather and mechanical damage. Common problems are pinched and chafed cables, corrosion (in cable or connectors), and water inside the cable (it's a dielectric with a screen spaced apart from the core - in cheap cable the spacer is permeable and can fill up with water).
