doug748
You can dewinterise it very easily. New filters, drop the oil and replace, bleed and give her some serious pre-heat before you turn the key.
If she's ashore stick a garden hose up her raw inlet .....
There is always someone with a flat cap and Woodbine who says: " I wouldn't do that Mister"
It is one of the less endearing features of these columns.
Beware the man who does not dot every I and cross every leg. There is some sad sod somewhere who can cranny out a vapid comment. So here I am.
If you shove a hosepipe up a raw water inlet, served with a Jabsco type pump, often enough you will eventually flood the cylinders with water. It is a very bad plan.
In my defence, I plead that this really is a bad idea.
