MikeSutherland1956
New Member
I have advised to use sikaflex to seal the bevel...
Did this some years back. I was very lucky to find a thick teak plank, which milled down into enough 50x6mm strips. All epoxy, with graphite mixed in to give the 'payed seam' look. Lots of sanding, but looked very good.It would if you could get thick enough teak. You would need to lay it properly with a caulking bevel, caulk and then paye it. Alternatively you could lay a ply sub deck, sheath it with e-glass (using polyester or epoxy) and then stick a thinner teak deck down. Will be much cheaper.
What wood did Scottish fishing boat builders use on the decking ?Any ply sub deck will fail, it is the nature of the beast that they do, water gets in & rot starts. A builder i knew did a small run of steel boats with laid decks, he used 12mm birch ply as the subdeck with teak glued & screwed to the top.
His argument for using birch ply was that "It takes screws well"
They looked good but birch is not durable & the one boat i saw later was having serious trouble at 15 years old.
As for using polyester resin, it is cheap but does not really stick to wood that well, delamination is a real possibility.
If you want a deck to last glass cloth & epoxy is the way to go.
The price of teak is now so high that it isnt an option unless you are very rich, Or lucky!
It will if you don’t sheath it properly or screw through into it. Polyester does stick especially if you use accelerator painted onto the ply first. We managed to get a load of teak offcuts (from a local super yacht builder) which we milled down to 8mm thick. Stuck down with EBT and caulked with TDS.Any ply sub deck will fail, it is the nature of the beast that they do, water gets in & rot starts. A builder i knew did a small run of steel boats with laid decks, he used 12mm birch ply as the subdeck with teak glued & screwed to the top.
Usually a durable white wood such as larch or Douglas fir. And the decks often leaked after a few years. But the fishermen just put up with the odd leak!What wood did Scottish fishing boat builders use on the decking ?
