Clancy Moped
Ask what Spoons use, that stuff must be bulletproof.
Almost certainly amtico.Ask what Spoons use, that stuff must be bulletproof.
If you want your boat to feel like student digs.Google ‘Flotex ‘carpet.
loose lay or stick down.
Scrubable.
Long lasting.
comfortable underfoot.
good range of colours/patterns.
indestructable.
I decided against a deep pile carpet on the grounds that I would be forever losing my pencils.If you want your boat to feel like student digs.
Check the link I did earlier.
My gin palace has way more floor area than a similar sized yacht. And it’s 46ft.
The carpet cost about £300 and it’s luxurious. Who cares if it doesn’t last forever. Replace it.
I tried wool carpets once and they rotted. Also tried some with a 'foam' backing that just feel to bits. Best carpet is a 100% poly type that just seem to shrug everything off.I've tried offcut from good quality wool carpets, but they just get soggy and go musty.
Anything with wool in stinks when it gets wet. And you can’t bleach clean it.I tried wool carpets once and they rotted. Also tried some with a 'foam' backing that just feel to bits. Best carpet is a 100% poly type that just seem to shrug everything off.
No carpet at sea. For harbour ambience we use small area rugs, strategically placed. They are easily shook out and can be run through the laundry when they get too salty/dirty. IKEA is our favourite source, go for man-made fibres.
I don't think I have that option as my floor is paint splattered and there are screw heads showing.![]()
I prefer comfort over hardwearing and change it every 7 years.Cover it in Amtico then you have a new floor that is hard wearing.
It doesn’t get smelly if you use polypropylene.You can always put small rugs down and on a sailing boat a good hard wearing floor is preferable to a fitted carpet which will inevitably get wet and smelly different for a mobo.
For a Mobo there is generally more shelter and you don't get people coming into the saloon off watch from the cockpit in wet oilskins, Amtico is a synthetic floor covering used in houses and top end motor yachts and yachts. A wet floor inside the yacht with such a floor covering is easily and quickly dealt with unlike a carpet where it stays wet until it can be taken out and dried, also the inevitable spills from the galley are easily dealt with. Hence synthetic or wood flooring with a rug if one wishes for when in harbour and slippers for below decks.It doesn’t get smelly if you use polypropylene.
My carpet gets wet and it just dries again. I don’t understand why you think a motorboat is different.
Don’t get me wrong I like wooden floors. I have them in my house. I just prefer carpet in a boat BECAUSE it gets wet.
If you prefer wood floors in your boat then fine and I’m sure it looks lovely.
Ok youve got me thinking.For a Mobo there is generally more shelter and you don't get people coming into the saloon off watch from the cockpit in wet oilskins, Amtico is a synthetic floor covering used in houses and top end motor yachts and yachts. A wet floor inside the yacht with such a floor covering is easily and quickly dealt with unlike a carpet where it stays wet until it can be taken out and dried, also the inevitable spills from the galley are easily dealt with. Hence synthetic or wood flooring with a rug if one wishes for when in harbour and slippers for below decks.?
My galley floor needs refinishing. Lots of dents. And a previous owner dragged the fridge out carelessly. I was going to sand fill and varnish.
Then I figured it would be a good substrate for amtico.
What pattern did you choose - got a link?
