BartW
In order to make the stringers really concurrent to the whole structure, it's necessary to build some "L" shaped steel plates, bolted through the stringers and supporting the pull of the external bolts, rather than having only the transom supporting the whole effort.
Below I added in blue the "L" plates on stbd side, with a couple of through stringer bolts in red (obviously there should be more), to better show what I mean.
all understood MapisM,
The stringers are GRP'ed on the transom with a 8mm thick x 100mm wide GRP flap,
see picture red arrows.
dont you think that a flat plate with slot holes for the nuts ,
and pushing that plate in the croner transom > stringer
would be sufficient ?
ofcourse L-shape is better, but difficult to make and fit.
the cross section of the stringer is not rectangular,
100mm (transom side) x 280mm x 75mm (visible side)
and the corner has a big radius
