samfieldhouse
Annoyingly the boat was out of the water a couple of weeks ago. And a week later following a stay in a very weedy Newtown Creek, the inlet appears to be blocked.
With the inlet pipe disconnected from the seacock and popped in a bucket of water, the heads pumps fine. So all the plumbing between the seacock and the heads is fine.
With the inlet pipe disconnected I've scraped around inside the seacock and removed some weed.
With a length of pipe connected to the seacock I've both blown with the dinghy pump and sucked with a manual hand bilge pump.
With the bilge pump I'm sucking a very small amount of water through, and with that pipe held below the water line there is no water gushing through.
With the seacock open I've also poked a length of wire down but it doesn't seem to get further than the seacock.
So my assumption is something is well bunged into the inlet between the seacock and the sea.
I even wondered if the seacock was stuck closed, but the blockage occurred whilst pumping - and when she was out of the water I greased the seacock and could see it opening and closing form outside.
I'm assuming I'll just have to dry out and poke from the outside, but any thoughts appreciated.
