snowleopard
Re: Bleedin\' Diesels
i thing the arrangement you suggest (tank between lift pump and final filter) could cause problems. the system is designed to have the lift pump feeding the injector pump. if you put a tank in between this arrangement is disturbed and the injector pump would rely on gravity and its own suction. if the tank were sealed it would provide the pressure but would also collect any air and need to be bled occasionally.
if you took the output from the lift pump to the primary filter then back to the final filter you would be able to bleed the whole system using the lift pump.
