rex_seadog
Blakes\' seacocks.
When sailing well-heeled we experience problems with water backing up the heads outlet pipe and overflowing from the bowl. With the Delta's virtually non-existent bilges this water soon finds its way throughout the boat! This happens despite religiously closing off the seacock - a Blakes' 1 1/2 inch. Before anyone comments about looping the hose well above the waterline, on our boat there is insufficient space to easily do this.
Anyway, a couple of weeks ago with the boat out of the water we decided to bite the bullet and remove the seacock (following excellent advice in a thread from about last March) with a view to refurbishment or renewal. I had always thought that tuning the handle through 90 degrees from the 'on' position closed the valve. However, on close inspection I realised that a further 10-15 degrees is necessary before it is completely closed. Is this the cause of all our problems? I'm now tempted to grind in the cone (as we do every year) and refit the seacock with Sikaflex and new bolts (three of the old ones sheared off with very little force). What are your thoughts? I note that the latest Blakes's seacocks are fitted with grease nipples - how much difference does this modification make? I have always greased each season with a waterproof grease (red and quite sticky) sold for trailer bearings. Is this OK or should I use the Blakes' product?
