sailorbenji
Hi all.
In a bit of a pickle (at sea in very low winds as I write this).
I felt a floorboard very hot by complete chance. It’s the engine battery under there and it was at about 55 degrees case temp before I stopped the engine.
I suspect the battery has gone bad. The alternator was pushing 30 amps into it but the voltage won’t seem to go much above 13.3V.
The battery will still start the engine and it’s slowly cooling down now but I’m not sure I can run the engine for any length of time as the battery was fizzing.
We’ve got a Yanmar 4JH80 CR diesel engine, almost brand new. The belt also runs the coolant pump so I can’t just take off the belt.
Things at my disposal are
1. A lithium jump pack
2. A 24-12V 12A converter if I needed to keep the engines electrics alive somehow (presuming that would be enough)
Any good thoughts on how I might be able to get myself in a position where the engine is up and running, but the battery isn’t getting stuffed with amps it can’t take “?
