PhatMan
HELP! Boat is a Ranger RP190 aluminum center console. The second year I owned the boat the Bilge pump would come on with Auto switch and not turn off, I assumed it was the pump and changed it. When I changed it the Auto would not work but the pump worked with the Helm switch, well 4 years later I decided to change the bilge because I leave it in a wet slip while we camp and the first couple of days we are expecting rain on our next trip. Now on to my issue, the pump still works with the Helm switch (new pump) but when I test the float switch (internal) it blows the fuse. This is a brand new pump, utilizing factory wiring. I assumed I had a bad pump so I bench tested it with a fuse inline, pump works in manual and auto with no issues. I chose to bench test my old pump as well, turns out the auto function works on that one as well and the pump it good. The hot wire for Auto is wired directly to my rear battery (just like factory) and the rest of the wiring harness runs to the center consol. I pulled the wiring diagram, the entire system shares a ground directly from the battery. I have tried everything I can think of, breaker fuse at helm is fine or the manual pump switch would not work. Why would it work in manual and not Auto? I also tried to wire it auto and ground direct to battery and manual to the switch wire in the harness, the pump will not come on with the switch and still blows the fuse on auto.
