304
Hi all . I’ve recently purchased a boat with the above engine on .The broker didn’t really go through the process of starting procedure,my fault as thought it would be straight forward . Before purchase the engine did have a problem with the tilt / hydraulic ram but this turned out to be a wiring connection problem apparently. The battery needed a good charge which now has been done and I tried out ram and all good .Turned on ignition and all instrument lights came on with gauges all working. Yesterday I wanted to move boat out of garage and no ignition cluster lights came on and ram not working ? There is 12v power to starter motor and also to aux equipment like radio and bilge etc . Not sure what to do next I assume power goes to engine then returns to ignition switch then back again .? Does the ram only work when ignition is on ? The engine doesn’t turn over either so wondering whether there might be a trip or fuse somewhere ? Any input would be appreciated. Did go out on sea trial and all good !, Thanks Mark
