Big motor - small boat
goeasy123
10 Nov 2018
What are the implications of putting a 15hp 2-stroke motor (relatively light) on a 2.5m roll up/airdeck/keeled Highfield design for a 6hp 4-stroke, apart from not gunning it?
I have an opportunity to buy the motor, but can't get a bigger RIB to suit it for a while, so I've got to use my existing 2.5m dingy.
B27
26 Jul 2023
The weight of the motor will twist the transom.
The thrust of the motor will twist the transom the other way!
A 15HP 2T may not be much heavier than a 6HP 4T.
If it's short-shaft you might get away with the thrust.
If you potter around with the 2T it might oil the plugs.
jwilson
22 Jul 2006
I once submerged the transom of a small wooden dinghy by giving a 4 hp motor full throttle. Damp experience....
Or you might just go very fast.
Tranona
10 Nov 2007
Maximum is 6HP DO NOT EXCEED
You will be a danger to yourself and others. There is a reason why the design limit is 6HP and if you attached a 15 you would find out why very quickly as the boat will invert as soon as you open the throttle.
Aja
6 Nov 2001
Is there a category in the Darwin Awards for this?
Boathook
5 Oct 2001
Surrey & boat in Dorset.
You could try it but any insurance would be invalid if something goes wrong. You would / should be ok with 8hp but would need to be careful. Again insurance ....
