That's certainly what I have done, with the connection in the mast to prevent UV damage and a drip loop on the outsideNew tricolour, and current arrangement. Thinking inline crimps with a couple of layers of heat shrink but wondering about UV resistance.
Can you not open up the unit and connect internally with existing cable?New tricolour, and current arrangement.View attachment 175971View attachment 175972
Bet you £1 it's not LED.What is wrong with old Tricolour?
Sorry, those connectors are absolute rubbish.I've just fitted one of those lights and used these connectors, with a length of glue lined heat shrink over the top:
Amazon.co.uk
One of my customers used them to join the masthead lights wiring after having the mast off. They looked tidy, but when pulled the wires heat shrink stretched until it broke, revealing wires with no solder on them, they were just held together with the glue and heat shrink.I have to agree ... I watched a video of them - seemed so easy and good .... till they get in your hands and you try it yourself ...
I had a simple RC motor lead to extension to make ... after 4 connectors failed to make secure joints ... I gave up.
I have a big boxfull of them sitting on the side now ...
For something at the mast head that is not easy to get to if it goes wrong ... I prefer corrosion proof plug / socket or hardwired joint ..
One of my customers used them to join the masthead lights wiring after having the mast off. They looked tidy, but when pulled the heat shrink stretched until it broke, revealing wires with no solder on them, they were just held together with the glue and heat shrink.
A better option where this type of connection is suitable would be the ones that you crimp and then heatshrink (glue lined).
Yes this is exactly the reason.Bet you £1 it's not LED.
And putting LED festoon bulbs in an incandescent fitting is rubbish.
They seem like such a good idea!. I, too, have a boxful that this thread reminded me that I need to bin. The heat-shrink crimp connectors do work, though, provided you use the proper crimping pliers. The ones that double as strippers just don't do it.One of my customers used them to join the masthead lights wiring after having the mast off. They looked tidy, but when pulled the wires heat shrink stretched until it broke, revealing wires with no solder on them, they were just held together with the glue and heat shrink.
If you do replace incandescent with LED,you need to ensure that the colour of the Red and Green filters in the housing matches the LED output. Or you end up with a very dim sidelight.
