MontyMariner
Lidl / Aldi 20v Multi tool / Angle grinder for the thick bits, but on a dinghy, you may well be able to cut a lot of it with Tinman's snips or even long handled garden tree branch loppers.
29th November 2023
I need to cut up my GRP dinghy, or pay to keep it where it is for another year. Sad, because I had hoped to sell or give it away, but there are no takers.
I have a fairly new Bosch 18v grinder with plenty of batteries and several of the very thin DeWalt diamond/steel cutting discs.
I'm only reluctant because I want to minimise the dust (although the dinghy's hull is much lighter than the OP's hatch surround, so will be less work).
Perhaps I should go at it with a sledgehammer, although I need the wreckage to be neat manageable pieces to take to the dump.
I could probably be persuaded to invest in a Bosch cordless jigsaw or multitool, which would work with my batteries.
What's the best tool for quick results, on the basis that I really don't want to be crouching in clouds of deadly dust?
It's probably advisable, if cutting thick grp, to use blades designed specifically for the job. e.g. DeWalt DT2056QZ Jigsaw Blade Extreme TC Tipped blade for Fibreglass T341HM : Amazon.co.uk: DIY & Tools
It's also certainly advisable to use 'full-on' PPE, for tiny glass fibres lodged in the bronchioles will certainly kill you, albeit more slowly than coronavirus. A filtering half-face mask of Grade FFP3 D - better still, a Half Face Respirator with P3 Cartridge - is what is needed, together with eye protection. Here's one source of info - Dust Mask Ratings: FFP1 vs FFP2 vs FFP3 - The Ultimate Guide
Such masks need to be properly fitted - otherwise it's a waste of money and a self-deception.
Builders merchants e.g. Travis Perkins, Tool Station, Screwwfix, have supplies.
('scuse my digital stutter )
Cheaper makes are equally as good for hobby use, it's the blade that does the work, so buy good blades.The multi-tool in the vid below looks very effective, but I'd rather buy Bosch as I have their 18v batteries. Are other brands likely to be equally good?
I would consider a circular saw with a blade intended to cope with nails etc.
Advantage being the waste is chips more than dust, and my circular saw has a fitting for dust extraction.
I get 'a vacuum cleaner is not PPE', but if you can trap the majority of the fallout at source, that can only be good.
There's a company called Perma Grit who sell very high quality TCT cutting and sanding tools, made for use with exotic laminates. They do really excellent jigsaw and hole saw blades that will cut a nice smooth line through GRP.
