Best tool or blade for cutting thick fibreglass
dancrane
29 Dec 2010
A manual snipper is a neat idea for dust-free cutting, thanks! I reckon I'll be in for some cost regardless, whether I spend on something like a branch lopper that I'd never need again, or a multi-tool, or just a fully protective respirator for the specific purpose of using the grinder I already have.
The multi-tool in the vid below looks very effective, but I'd rather buy Bosch as I have their 18v batteries. Are other brands likely to be equally good?
MADRIGAL
12 Jan 2019
29th November 2023
I need to cut up my GRP dinghy, or pay to keep it where it is for another year. Sad, because I had hoped to sell or give it away, but there are no takers.
I have a fairly new Bosch 18v grinder with plenty of batteries and several of the very thin DeWalt diamond/steel cutting discs.
I'm only reluctant because I want to minimise the dust (although the dinghy's hull is much lighter than the OP's hatch surround, so will be less work).
Perhaps I should go at it with a sledgehammer, although I need the wreckage to be neat manageable pieces to take to the dump.
I could probably be persuaded to invest in a Bosch cordless jigsaw or multitool, which would work with my batteries.
What's the best tool for quick results, on the basis that I really don't want to be crouching in clouds of deadly dust?
:cry:
afterpegassus
12 Mar 2009
NW scotland
It's probably advisable, if cutting thick grp, to use blades designed specifically for the job. e.g. DeWalt DT2056QZ Jigsaw Blade Extreme TC Tipped blade for Fibreglass T341HM : Amazon.co.uk: DIY & Tools
It's also certainly advisable to use 'full-on' PPE, for tiny glass fibres lodged in the bronchioles will certainly kill you, albeit more slowly than coronavirus. A filtering half-face mask of Grade FFP3 D - better still, a Half Face Respirator with P3 Cartridge - is what is needed, together with eye protection. Here's one source of info - Dust Mask Ratings: FFP1 vs FFP2 vs FFP3 - The Ultimate Guide
Such masks need to be properly fitted - otherwise it's a waste of money and a self-deception.
Builders merchants e.g. Travis Perkins, Tool Station, Screwwfix, have supplies.
('scuse my digital stutter )
Passive dust masks are also pointless unless you're clean shaven.
SvenH
28 Mar 2011
The Netherlands
No one has mentioned a circular saw yet... Probably needs teeth with negative tooth angle and is not for the faint of heart.
Angle grinder is probably the best option for speed, jig saw keeps the mess most local.
A vacuum cleaner is not ppe.
Refueler
13 Sep 2008
Far away from hooray henrys
I remember cutting the hole for speed log in my 1970's boat ... 50mm solid GRP ..... took 3 good hole saws to get through .... GRP just wore out the teeth as though they were butter !!
GRP repair guy doing my bilge keel joint - has used grinder for 99% of the work and a reciprocating hand saw for rough stuff ... I now have a devils job to clean up inside the boat !!!
B27
26 Jul 2023
I would consider a circular saw with a blade intended to cope with nails etc.
Advantage being the waste is chips more than dust, and my circular saw has a fitting for dust extraction.
I get 'a vacuum cleaner is not PPE', but if you can trap the majority of the fallout at source, that can only be good.
I have a reciprocating saw, imitation 'sawzall' which is ultraviolently effective and the blades are cheap.
What you need to know, is how small must you chop it up?
I've seen videos of whole Laser hulls going in the skip at the recycling centre.
The other possibility is to talk to a 'down to earth boat yard'. They get rid of boats from time to time and may make space in their skip for a fee.
Or you could ask a commercial waste company, they will just drop a skip on it a few times and sweep it up, then invoice you...
Other possibilities include cutting useful panels out of it, re-purpose bits of it into a garden compost bin or something!
When you want a fairly flat bit of GRP for a bodgery project, there's never a scrap dinghy handy!
geem
27 Apr 2006
Caribbean
I had to drill new holes through my deck to fit new genoa tracks. The genoa tracks have aluminium plate glassed into the deck for reinforcement. With brand new drill bits, the drilling process of first going through grp then into the aluminium was shocking. By the time I had drilled the grp, the drill was blunt. There was no way I could then drill the aluminium. Any drill bit or mutiltool blade, jig saw blade will suffer the same fate. Grp is terrible for blunting steel.
I would suggest, as other have done, to use 1mm angle grider cutting disks.
MontyMariner
7 Apr 2011
Somerset / Dorset border
montymariner.co.uk
Cheaper makes are equally as good for hobby use, it's the blade that does the work, so buy good blades.
As you have Bosch battery then there is a good argument for buying Bosch as the battery plus charger is a fair percentage of the price.
Don't you have any DIY mates / acquaintances that could lend you a tool or two?
requiem
20 Mar 2019
From my forays into woodworking I like the "chips vs dust" distinction. If you can see it in the air, it's too large to be a problem for your lungs. It's all the tiny particles too small to see that are 1) getting flung everywhere, 2) the long-term health hazard, and 3) not adequately picked up by most dust-collection methods. (I also happen to have a relative who worked with fiberglass in his younger days and is now paying the price.)
Thus, I'd second the idea of taping up a sheet of plastic to guard the interior and using disposable coveralls so you don't contaminate belowdecks. A vacuum is certainly good for tidiness, and a good breeze can take care of what it doesn't catch.
PetiteFleur
29 Feb 2008
Suffolk
I've used a jigsaw blade which is specifically for grp - not cheap from memory but it works well, from local builders merchant. Not sure if you can get a similar blade for reciprocating saw.
dancrane
29 Dec 2010
Thanks for so many good suggestions - whether they relate to the OP's question or my own.
Given how ineradicable (and barely detectable) the airborne product of fibreglass cutting or grinding is likely to be, I can see it's crazy to attempt the job (whatever the tool) without full recommended respirator, eyewear and some sort of chuck-away overalls to ensure the dust isn't transferred into the car and home. I'd rather be careful than regretful...
...so as long as I'm going to cover up thoroughly, and since the work will all be outdoors, I might as well use the grinder I already have.
We'll see, I may only be busy for 20 seconds before I decide I'd rather shell out on something tamer than the grinder.
I read somewhere else (sorry if it was somewhere here!) that a tungsten carbide scoring knife is effective - neatly scoring a line in the fibreglass which then cracks easily and cleanly if given a swift kick. It sounds basic but it may be ideal for reducing mess.
Of course, I'd still gladly give the boat away, whole...much happier all round.
Refueler
13 Sep 2008
Not so positive about 'chips rather than dust' ... gives me thoughts of 'blade' ripping and splintering the cut line ...
GRP has a terrible habit of not clean cut line if cut coarsely .... thats one of the reasons that its best if possible to cut from the 'underside' so any Gelcoat is not splintered by action of blade 'lifting it' ...
Same idea as cutting ply / wood etc .... have saw enter at the hidden side - not waht will be the face ... to avoid those missing ripped out chips !!
MisterBaxter
9 Nov 2022
There's a company called Perma Grit who sell very high quality TCT cutting and sanding tools, made for use with exotic laminates. They do really excellent jigsaw and hole saw blades that will cut a nice smooth line through GRP.
