RupertW
So I started off with anchor watches many decades ago, then moved quickly to alcohol instead. Transits followed and I still do those but those will just confirm whether you have moved when you are already awake and up in the cockpit. After that I used shallow and deep depth sounder alarms which are great, would wake me up with plenty of time in most situations but are limited where there is a very shallow slope bounded by rocks.
So now I use the Anchor! app on my phone which sits charging beside me when I sleep - it allows you to set a margin preferably longer than the chain you have out and allows you to re-centre where the anchor probably is. It works well although typically only goes off when we up anchor and motor.
Of course the real trick is anchoring technique including digging in hard in reverse (building up revs very slowly) to test the seabed. Chances are if full reverse can’t shift it then you can sleep much better, even with turning tides or changing winds.
