dunedin
Good point about choosing weather and not over relying on technology.My advice to the OP......if this is your first night at anchor follow all the good practice here, but chose a forecast with a sensible wind strength, no more than a force 4 absolute max. My own experience of anchor alarms is they just generate a lot of stress........the time to learn to use one is once you have experience of anchoring and transits. I've tried to use one a few times and invariably switch them off. Is the only way to use one to start it just as the anchor hits the sea bed? Bit tricky at the bow as I lay out the chain.
But Re anchor alarms, the one on our Raymarine plotter is rubbish, for the reason you give - just a range from a fixed point.
BUT use something better like Anchor on a tablet and massively better. Can set up any time after dropping anchor, even a day or so later, and then draw whatever shape of alarm boundary that you want. Let it run for 10 minutes or so and will see the shape of the curve as swing to the anchor. Then draw the shape you want, allowing for a bit more swing on the same trajectory.
Adjusting the shape can get it to alert you if wind changes and swings towards an obstruction or shallow, and depending on preference can get to alert if swing in opposite direction, or draw circle so doesn’t alert on tide turn unless move outside cable length.
So far had NIL false alarms, but a small number of wake ups when forecast wind shifts came through and I wanted to check things due to rock proximity (but not having dragged). Dont use when calm, settled and plenty of swing room, but certainly doesn’t cause stress but allows peaceful sleep when more windy and/or restricted.
