Best chain join
keplero
20 Nov 2001
Italy, Rome
Could someone tell me the best way to join two lines of 6mm chain? I have done with a proper false link.....but... I am not sure.
Thanks to all.
Max
hlb
RIP
Any Pub Lancashire or Wales
That should be ok. If its the one with screw together fixing.
Cant think of another way except welding one in.
But like others have said, might not go round the gypsey.
Haydn<P ID="edit"><FONT SIZE=-1>Edited by hlb on Mon Dec 31 16:47:35 2001 (server time).</FONT></P>
The chain can be welded and still run through a gypsy.
The welder needs only to be careful and not leave alot of bead or a sloppy weld. The inside of the link can be
cleaned as well. If properly welded the link will be stronger than the chain.
I have the same concerns as I have intentions of joining two lengths of chain for my anchor. The results I have
found on my own research are as above.
Good luck!
