Alex_Blackwood
Why would we challenge that?? You hang on to itIt wouldn't be the same without them.
There will always be somebody challenging my position as forum idiot...I'm used to it....
You would be surprised, there are some that I'm finding very difficult to fend off.Why would we challenge that?? You hang on to it
Come to think of it you must be the only one that hasn't got me on ignore
Not Brownie points, IMHO. More like something else brownI understand where you are coming from as there are some who just to get brownie points
I'm familiar with that, is on par with tinnitus..."You're an idiot who's never understood anything in your life"
Nothing drives me away from an otherwise interesting thread quicker than personal insults. You can tell someone they're factually wrong without personal insults - evidence works much better to instruct people. You can even offer a alternative opinion politely - it's allowed. "You're an idiot who's never understood anything in your life" is not an alternative opinion (even if it is correct), nor is is banter.
KNOP is knot in English, so the display likely shows speed.Here's the panel ...
Thinking to install a 3 pos switch to make Voltmeter show Domestic or Engine ... (I have that on my other boat ... )
The KNOP meter ?? not sure what to do with that !!
Same KNOP meter is sat in middle of above displays ... thinking to remove it and put my engine RPM display there instead.
You always wanted a 240/110 transformer....now you can justify....!@#$%^&*( ..... just received a new charger ... User variable voltage .. User variable Amps .... Pulse settings .. Maintenance settings .... nice piece of kit ...
Then I noted - 110 - 120V only !! No its not even universal .. so now I need an adaptor to step down 240 to 120 ... DRAT DOUBLE DRAT !!
Bought it based on a recc'd from close pal .. he sent me the link ... I gave it a quick look - basically looked at the modes and ordered ...
It was when I took out of box and noticed the US flat style two pin plug ... UGH !!
My engine room pump is connected to a Whale sensor, works well ( the model with a 30 second off delay). They occasionally needs a wipe or they don't always switch off properly. Better than the Olde Worlde float switch IMO.The question now is whether to replace the pump (which works fine) with an all in one auto pump - or to replace the add on auto switch ?
I've had the solid state Water Witch before .. which was good for a couple of years then just became unreliable. I have a couple of the paddle type float switches - but they need quite a height of water before they activate etc.
Decisions ... decisions ...
