Alex_Blackwood
Have used these types of sensors in lots of different applications on ships. Like Paul has said they do need to be cleaned off now and then. Also it is possible that they could be sensitive to temp. extremes. Quite a few solid state(Electronic) sensors can be. Just might be worth a play with before discarding!Today I decided to have a go at the boat before the forecast snow starts again.
Lifted the two 75A/hr Lead acids on board - they were checked before leaving home and they have stayed at 13.2V for days now idle.
Dropped into boxes .... and connected up .. what was that noise ?? A gurgle and a buzz ......
Now I know what discharged the batts ... automatic bilge pump was stuck on ... I'd forgotten to lift it clear of bilge bottom when laying boat up. The pump is a strange pump I have never seen before with what I thought was solid state detector fixed to the side of ..... mmm I'm wondering if its not solid state as usually they do not stick on even with ice.
Anyway - for now I just cut the +ve wire and will sort out later.
This is interesting - when boat was afloat - we could not get the auto to work. Now we cannot get it to stop !!
Whoever wired it in was daft anyway .. on my other boat - I have a 3 way switch ... Auto - OFF - Manual ON. But this boat has only Auto - Manual ON with no over-ride OFF.
Once I get a new switch - I will swap out the 2 pos switch for a 3 way.
Another good bit of news - once I put the batterys back in .. the solar controller came to life showing LED's lit and feeding 14.4V out .... amps would have been very low but at least it was working. It has no display so I had already decided that I would swap out the controller for one with LCD display. 10 mins later - all done and now I can see at a glance state of the house bank ....
