morgandlm
I currently have a fairly simple two battery set-up of lead acid starter and domestic batteries each with a battery isolator. Both batteries are charged from the alternator through a Victron Cyrix VSR. I’m planning to remove the VSR and install a battery to battery charger but am undecided between a Victron Orion TR Smart 18 amp unit or a Sterling Power Saturn BB1225 which is rated at 25 amps. The Beta engine has a 40 amp alternator so the Sterling is perhaps over-rated?
I note that the Victron relies on an external heat sink for cooling whereas the Sterling has an internal cooling fan. I’d be grateful for any advice on the selection and feedback from anybody who has fitted either of these.
The domestic battery is currently a sealed lead acid but when it needs replacing I may upgrade to a LiFe PO4.
David Morgan
David Morgan
