Gryphon2
I need to replace 3 big AGM batteries which are rated as 160 Ah and C100. I have been told that I would get the same performance from a 140 Ah C20 battery. True or false?
The rating for the existing battery would be 160 Ah at C100. The C figure says nothing about the battery, it is just a qualifier of how the Ah figure was arrived at. Ah gives an indication of the energy storage capacity of the battery. Because this can be measured in different ways, for instance regarding discharge time (number of hours indicated by the C figure), this is normally stated to make comparisons between batteries easier. I believe C20 is most commonly used by manufacturers when declaring a battery's capacity.I need to replace 3 big AGM batteries which are rated as 160 Ah and C100. I have been told that I would get the same performance from a 140 Ah C20 battery. True or false?
Close enough.I need to replace 3 big AGM batteries which are rated as 160 Ah and C100. I have been told that I would get the same performance from a 140 Ah C20 battery. True or false?
Not worded quite right, although obviously your point is correct.is the energy a battery can deliver continuously for 20 hours
