Battery boxes lids
ridgy
26 Jan 2003
North West
Thought I might do the decent thing and add some battery boxes to the setup but then I started wondering how you put the lids on since the cables would be in the way?
The lids seem to have areas that look like they should be cut out but even then how do you attach the cables which are now under the lid?
dankilb
23 Jan 2008
They should really be vented to atmosphere...
In that case, I understand you make a cutout for the cable exit around half way up the height of the box. Logic being, gas rises and vents out before it collects enough to escape through the cable entry. But you don't want the hole too low, in case the battery spews acid!
Refueler
13 Sep 2008
Far away from hooray henrys
Unbeknownst to me - my previous gardener disconnected my power to boat few winters back ... one battery discharged - temps dropped and battery case cracked ..... what a mess -
Luckily my battery box is a ply built in affair with thick epoxy paint on inside - base and sides, so it was all contained.
Pete7
11 Aug 2004
Gosport
How do you intend to secure wobbly plastic battery box down, so it doesn't go flying in a knock down?
You might also search e bay for GRP battery boxes which tend to be used by the off-road and performance hill climbing lads. Fitted one to a previous boat with bolts and metal plates. Price was quite reasonable at the time and compared to wobbly boxes.
Refueler
13 Sep 2008
Most boxes I see have straps over back to fixings .... simple to glass a webbing end and buckle to secure box.
Seashoreman
24 Apr 2012
Aldeburgh, Suffolk. River Alde
www.pianotuning.uk.com
Personally I never intend to put myself in a situation were I would risk a 'knock down'.
No movement of boxes in regular use although I haven't tried turning boat upside down :D (yet).
There are so many variables and differences in our sailing endeavours and I sail coastal solo with care and attention to
the risks of extreme weather.
I am more concerned with metal objects (tools etc) hitting the contacts on the 3 batteries that have to share the same locker.
Although I am a fairly tidy person I always fear dropping stuff or catching a watch strap on an exposed powerful battery.
PetiteFleur
29 Feb 2008
Suffolk
I made a box for my engine starter battery with plywood, screwed to engine bearers with a hinged lid secured with ss overcentre clips, ventilation around the top and a central spacer strip so that when closed the battery was firmly located. Slots for the cables and varnished. Works for me, no problems after several years. The original battery box now has two house batteries strapped down.
Refueler
13 Sep 2008
Having seen the consequences of short on a battery ... its something I do not care to see again.
The battery literally split and guys hand was permanently disfigured / damaged .. he was lucky the acid didn't hit his face ..
I hop that you at least cover the terminals to prevent any change of a short ... even it only covers for each terminal ... or a shallow ply lid fixed over top ....
colind3782
18 Jan 2011
Shropshire/Empuriabrava
Whenever I am working on or around the batteries I lay a plastic bag(s) over anything that might short.
Refueler
13 Sep 2008
You'd think I would be more careful having witnessed an 'event ' ........
I was fiddling with one of my garden tractors ... small Lead Acid 30 A/hr battery .... I was using a large screwdriver ... I mean a big screwdriver ... about 15" long .... ZAP .... in the short time it 'welded' itself to the battery post - it had burnt away half the shaft diameter ........
Simply put - the amount of energy that can be put out is astounding. Even a small AAA rechargeable ... I had in pocket left a scar on my leg ...
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
Might not agree with some peoples ideas ... but I am against boxes that seal or near enough seal ...
The chances of a plastic battery box and its lid sealing hydrogen gas inside, or anything near it, are zero. Hydrogen is one of the hardest gases to contain because of its small molecule size, beaten only by helium. It's also pretty good at diffusing rapidly (the molecule's temperature induced velocity at the top of the atmosphere is so high it exceeds the gravitational escape velocity there and escapes into space, which is why there's almost none in the atmosphere). And it can work its way into and through solids. The equipment needed to contain it both safely and without it escaping is expensive and complex, which is one of the many reasons why hydrogen powered cars are not coming any time soon. An approximately fitting lid on a plastic battery box retaining any significant amount is a non-issue.
AngusMcDoon
20 Oct 2004
The amount of power that can be put out is high, especially for lead acid batteries that have a very low internal resistance, hence heating a screwdriver shaft to red hot in seconds or turning over a big cold diesel engine. However, the amount of energy? Meh. Batteries are useless at that, especially the specific energy value compared to mass for lead acids. The theoretical total energy stored in a 100 Ah 12V lead acid battery is about the same as a third of a mug full of petrol; the useful energy is half that.
Refueler
13 Sep 2008
You should see what you can do with a Lithium battery .... especially some of the LiPo's we use with 100C rating !!
Its not the total amount of 'energy' - its the rate at which it can be discharged ..... Lead Acid are way behind LiPo as example ... but still not to be ignored.
Refueler
13 Sep 2008
I prefer NOT to take the chance ...
Having a nose that has on many occasions got a 'whiff' of the H put out by charging batts ... especially strong when in a confined space ... whether its enough to ignite or not - I prefer not to chance.
My work involves Tanker Ships and that instills a strong wish to avoid even the slightest risk of any flammable gas ....
I am aware of the problems to create H cell powered vehicles - but its far more than just containment ...
Stemar
12 Sep 2001
If you can smell it, it isn't hydrogen. The nasty smell that (usually knackered) batteries can give off is hydrogen sulphide, which is a lot nastier than H2, as it's a bit heavier than air and is flammable enough to be explosive in the wrong conditions.
