Why is our rudder so heavy?
28 Aug 2024
The rudder for our 19874 FoxTerrier 22 is really heavy - not weighed it, but I'd say it's somewhere between 30 and 40kg.
Why? I know a rudder has to be strong, but was it just the way they were built back then?
I'm wondering how hard it would be to fabricate a lighter one with ply and GRP...
KevinV
12 Oct 2021
By the shape of it that rudder looks like it's made from ply already - probably really good quality stuff if it's lasted this long. The weight doesn't affect you one bit once it's on the boat, I'd leave well alone.
FWIW, mine's fibreglass in two halves and weighs about 30kg too (more when the core was waterlogged!) - same size boat.
Hoolie
3 Mar 2005
Hants/Lozère
We have a similar, but a lot larger, solid rudder. It has at times been subject to impact so personally I wouldn't dream of replacing it with something less robust!
Snowgoose-1
2 Jun 2015
If it's a lift keel version , the rudder will have to be bigger. The Anderson 22 is a lift keel and has a wooden rudder which is quite heavy. Yours may be like this.
Chiara’s slave
14 Apr 2022
Western Solent
It has to be heavier than it's displacement
I don’t think that is so. It might help, if it were to be hung on pintles with no means of retention apart from gravity, but that would surely be the height of foolishness. Ours is definitely heavier than water, but as it’s held down by a powerful downhaul system, it wouldn’t matter if it wasn’t. I think it’s built around a thick stainless web, and has a lot of grp making up its solid shape. All for strength, not to make it sink. A simple transom hung rudder could be bolted or pinned onto it's pintles, no need to be heavy apart from it's need for stiffness and strength.
billskip
6 Sep 2001
I was thinking more on the lines of buoyancy, "trying to float" will surly attempt increase the heel angle, or create instability when heeled in a heavy sea.
Rum Run
7 Apr 2011
Me: Midlands, Boats: East Coast
The rudder on my Anderson 22 is similar in shape to the OP's picture and is solid iroko so not light at all. Possibly this one is also Iroko.
I had considered making a composite one, using closed cell foam and carbon fibre cloth, designed on the principle of trying to maintain strength but reducing weight. It started to look expensive!
Normal plywood has half the veneers going in a direction the does not help stiffness in a rudder, also it sucks water into the end grain and rots fast, plus is not low density so still heavy.
Maybe a lower density wood (spruce perhaps), with hardwood leading and trailing edges, all sheathed in glass cloth would be sufficient. Probably one of Gougeon Brothers technical guides has a scheme.
Snowgoose-1
2 Jun 2015
It might be fun using 3d printing for a new
rudder and then fill it with a material of choice
I would guess that most conventional rudders would sink if you took them off the boat .
billskip
6 Sep 2001
A question of scale. 10kg of buoyancy against a ton of boat? And that would be a big fat and light rudder.
I'm not arguing your point, however 10 kg of buoyancy is quite a lot when you are trying to sink it with a fulcrum point well above the centre line..
I would sooner have the weight working for me.
