billyfish
My almost new house Batteries are only showing 13.4 volts the starting Battery 14. They are 2 90 AH lead acid. Why won't they charge higher
OK they look OK. What i don't understand is the starter battery 80 AH reads 14 all the time.You don't say when the voltage readings are taken. 13.4 is a typical "float" charge for LA batteries. This means the battery is fully charged and the charger/alternator cuts the charge back. A fully charged battery will have a resting voltage of 12.7 to 12.8
All the time? Or all the time with engine running (or mains charger on)? How are the batteries linked - 1-2-Both switch, a diode, a VSR, etc?OK they look OK. What i don't understand is the starter battery 80 AH reads 14 all the time.
Difficult to make any sensible comment without knowing exactly how the charging is arranged - there are so many potential variations.I'm pretty hopeless with electric systems but get by. Which is why I've asked on here. I don't see any smart systems equipment to me it looks like the alternator charges the start battery then the house batteries. I leave solar on when not on board, seams to keep them up but no more than 13.4 v so I guess what you say is right and they are OK.
Or difference even.....there are so many potential variations.
This is a confusing description.All the time. With the engine running.
"Resting charge" seems like a contradiction in terms. At rest a normal lead acid will be ~ 12.7V fully charged. If the "extra" is coming from the solar panels and each battery is fed from its own solar that might explain it - if the panels are different sizes or oriented differently, or if the engine battery is "full" and the house is actually being charged. It would be a misleading assumption that a battery reading 13.4 but connected to any charging source is actually full.I think it's working fine and the resting charge at 13.4 is fine. thanks all for helping . They will get me through the summer and refit time coming I'm planing to upgrade to one of the more modern alternatives
