[70521]
Looking at Sailboatdata for a Fox Terrier 22 unless the OP is planning a TransAtlantic in it any time soon, @RogerFoxTerrier let us know if you are, there is a serious amount of over engineering going on.
Agreed. Nothing wrong with ply if it is protected from damp which is easy to d as several posts have suggested.Looking at Sailboatdata for a Fox Terrier 22 unless the OP is planning a TransAtlantic in it any time soon, @RogerFoxTerrier let us know if you are, there is a serious amount of over engineering going on.
The way I set it up, the new metalwork took all the strain. The acetal pad was a backup if the metalwork failed, as the original certainly had....a nylon-type material which is 'plastic'.... in that it deforms and flows under compressive load.
My Sadler 34 has no backing plates for the genoa winches . . . The layup is quite thick here and loading is in shear, needing no reinforcement.
True enough but the lever arm length is about 60 mm. The tensile and compressive forces are minuscule compared with the shear. My point is that on a boat that is possibly 50 years old it is most unlikely that the winches suddenly need backing pads.As I'm sure you know, the loading on a winch is not wholly in shear. The load from the sheet or halyard is above the base, so there'll be a compressive load on the side of the winch base and mounting on the side with the loaded line, while the opposite side will be in tension - i.e. being pulled upwards.
LOL - well I did Canaries to Antigua in 1999 but in a Beneteau 40, and not planning it again in a 22 footer!Looking at Sailboatdata for a Fox Terrier 22 unless the OP is planning a TransAtlantic in it any time soon, @RogerFoxTerrier let us know if you are, there is a serious amount of over engineering going on.
I used Tufnol to back the supports for Yacht Legs. Excellent stuff.I have used Tufnol or Paxolin (phenolic with paper or cloth) for backing pads. It is available in various thicknesses and small offcuts from the usual sources. I don't know the differences between the different types such as kite, whale and carp but they are all very easy to cut. At work we used to use Peek which was very expensive but the other varieties are quite cheap.
I hadn't heard the designation 'G10 FR4' before, but I believe I have several 1m. x 1m. x 13mm sheets of the stuff 'rescued' from a defunct company. Please see #15 for an offcut example.G10 FR4 is perfect as its super strong and last forever - its is expensive but you can buy small sheets quite cheaply on eBay which should be perfect for most backing plates . Then you just drill the holes you need through it, put it in place and forget it forever
