Sticky Fingers
Yup got those.
I'm not happy with the Autoterm 'Confort Controller. If I use POWER mode the heat output at max is fine. Use it in Temperature mode ie set to increase from where you are to where you want to be, and it doesn't try half as hard. I would expect it to go flat out then taper off as it gets there. It doesn't seem to do that, just dawdle along so it takes forever. I asked them about microcode updates and temp curves but they just wanted pictures of my installation.
This is exactly how my Autoterm works with the comfort controller.This isn’t the first time I’ve read this and tbh is probably the thing that has stopped me ordering up until this point.
My old Eber (in a camper van 10+ years ago) used to work beautifully. It would run flat out for a while and then when getting close to the right temperature would slow down, eventually to just ticking over so it stays alight but burns barely any fuel & used barely any power. Then would gradually ramp back up, to full power if it needed to and repeat.
I doubt that would work, but have a word with Owen at Autoterm UKHas anyone used the Autoterm push button control switch linked to the comfort controller? I have the comfort controller in the main saloon and thinking of putting a push button switch in the forward cabin so I can switch the heater on from bed. Just wondered if anyone had experience of this setup?
Ah, i hadn't seen that, i was thinking he meant a second controller, but this looks neat.
Is that the same idea as the remote control switch, as supplied as standard with Chinese heaters? Available for £5.Ah, i hadn't seen that, i was thinking he meant a second controller, but this looks neat.
Available here for £75 Autoterm Push Controller
No idea, never fitted a Chinese heater.Is that the same idea as the remote control switch, as supplied as standard with Chinese heaters? Available for £5.
Out of interest, would you, if asked?No idea, never fitted a Chinese heater.
Nope.Out of interest, would you, if asked?
No address, no phone number, just a hotmail email address...............................................Anyone had any dealings with this company?
Eberspacher Marine Heaters Diesel Heaters Night Heaters Yacht Heaters Boat Heaters
Yep. Doesn’t look great.
Cheap though, probably for a reason…
Edit: Based in Turkey.
If it looks too good to be true etc…
However, it’s still a chunk more expensive than an Autoterm and I don’t think it’s worth it.
