Attempted manslaughter
ParaHandy
18 Nov 2001
Once when entering Cherbourg in less than 50m visibility, there was a container ship parked a cable from the western entrance. His foghorn obscured the Cherbourg horn and he was holding station in a west going tide by running his engines astern whilst pointing west. I have never been so scared in my life before as I passed within less than a cable of her bows. If somebody had said of my boat ‘nice boat’ I’d have tossed him the keys and took the ferry. There are some nutters out there and the unease I felt then, grew as I read the most recent MAIB report.
In the very unlikely event that anybody will act to curtail the speed of commercial vessels in reduced visibility one wonders what tactics should be adopted to avoid a collision and whether the Collision Regulations are relevant in such situations. The fundamental problem is the disparity in speed. Where this is great, the yacht comes closer to the track of the faster vessel and this restricts the room for manoeuvre of either vessel and the angle of approach of the faster vessel becomes more acute and thus any errors in calculation of the track of the faster vessel tend to be magnified.
My premise is, almost, entirely mathematical and gleaned from boating on the Serpentine in London, you might say. But it did frighten me. However well planned a passage, fog is inevitable but what makes it toxic is the presence of very fast merchant ships who are completely disregarding the Collision Regulations.
For a yacht travelling at 5kn on a collision course forward of the beam with a container ship doing 27kn, contact at 6nm range by radar will be made when the yacht is 1nm away from collision, such is the impact of the speed disparity. The yacht skipper in these circumstances has two options: either switch the radar off and hope the container ship skipper is awake, hasn’t been on the bridge for the last 24 hrs, isn’t shorthanded, is in control, sober and not from some part of the world where human life is cheap, or, assume none of the above applies. There is a case for hitting the off button. The probability of a collision is statistically small but there are circumstances which decrease the odds eg passing close ahead of a container ship doing 27kn which most would instinctively try to avoid and in so doing and by using radar create a radar assisted collision.
My first premise is that if you, the yacht skipper, take more than 5 minutes from first seeing the target to determine and execute your collision avoidance strategy you are heading for trouble. In 7 minutes you are 4 cables away from a collision. There are significant system and human errors which can be dangerously misleading the closer you get.
My second premise is that a stabilized display which at the very least shows a North Up or stabilized EBL is essential. Calculating track, speed, CPA is all but impossible within the time you have available without such help. However, such aids are not of much benefit if you are not skilled in their use. A practical and well honed method of translating observed data into meaningful data upon which you can base your decisions is essential. In this regard, the practice of positioning the radar display in front of the helm is one that I question. Is the helm able to accomplish all that is required?
My third premise is never slow down. The faster you can go, the more room you give yourself. Substitute ‘radar’ for ‘foghorn’ in rule 19e for when reducing speed might be appropriate.
My fourth premise is never reduce the radar range to, say, 3nm. You merely make yourself blind to the one behind it and time is utterly of the essence. If there was only one rogue vessel intent on manslaughter then I could see the point, but there aren’t.
TonyS
23 Feb 2003
Southampton, UK
The answer is a screen with MARPA on the binnacle. You can select up to 10 targets up to 20 miles away. It is easy to see what ships are doing and what to do to avoid a collision. It took me a few minutes to teach my wife how to use it (effectively place the cursor over any blob on the radar screen and see what comes up in the MARPA box - speed, direction, closest point of contact and when). I don't believe there is any other good solution. With the screen below you need 2 people full time and the one looking at the screen often gets sea sick!
Tony
<hr width=100% size=1>Tony
Twister_Ken
31 May 2001
'ang on a mo, I'll just take some bearings
How about this
An answer from someone who doesn't understand radar,
Ok, let's imagine viz is good and you see a ship which is either on a collision course, or close to it. If there were no colregs to say which were the stand-on vessel, I would choose to turn parallel with the ship's course, either in the same direction as it or 180 degs opposite (unless I was well and truly across its bow) and wait for it to pass me b4 resuming my course. Unless there were a good reason not to, I would turn into the tide to reduce my speed over the ground, and not lose too much distance down tide.
Now you're in rotten viz, when std colregs don't apply, and your radar shows a threatening return heading your way. Why wouldn't you do the same thing?
<hr width=100% size=1><A target="_blank" HREF=http://www.writeforweb.com/twister1>Let's Twist Again</A>
Robin
30 May 2001
high and dry on north island
Sorry Tony but you cannot pick up ships at 20m range, just because the set says 24ml/48ml whatever does not mean it can see over the radar horizon. When the ship is close (ie <2mls) the echo may also form a complete circle around the centre, MARPA cannot work then any more than a human operator. MARPA may be helpful but it cannot be perfect in a yacht where a) the ships head is swinging about irregularly and b) the speed is not absolutely constant. It is much better on a stable platform like a container ship, but even they would not claim it is foolproof or you could teach someone to use it in a few minutes.
jimi
19 Dec 2001
St Neots
Re: How about this
Problem is not really single ship situations but multiple situations when altering course to clear one brings you closer to another. In that situation a Nort up display is best as the siplay an the relative positions do not change.
<hr width=100% size=1>.. whit way roon should it be again ..
Moose
1 Nov 2001
West Sussex, Boat in Chichester
MARPA is very very good when you have a wizzy round scanner.
Robin
30 May 2001
Well said
That more or less echoes (!) my thoughts too, though I would in extremis switch to 3ml range for a short time to separate target and self at the critical time, even reducing the gain to avoid the complete ring donut echo. You are right though to warn of the next one sneaking up whilst you do it.
Robin
30 May 2001
Re: How about this
In clear vis you can see his actual heading. On radar you can only see his relative heading, which by your defintion is coming straight at you! You could follow your scheme only if you ran a proper plot to determine his actual heading/speed and that does take time (ie requires a time between successive plots). We have a plastic plotting board with which to do such a plot but in practice this is rarely used because of the complexity with several vessels threatening and the limited time. Surprisingly the EBLs and 'trace' plot features are a big help, just so long as you don't go for small CPAs!
TonyS
23 Feb 2003
Southampton, UK
You can pick up ships at large ranges. What you do in a shipping lane is to alter the range every few minutes so you see what is coming. We have never had problems with short ranges either. The Raymarine equipment is excellent in this respect. It was the only equipment offered with my boat as standard fitment. The targets at large range tend to swing around a bit but this quickly settles down when they are closer and it matters. My boat in the channel is anything but stable.
Robin
30 May 2001
I don't think the scanner is that relevant though it does give a much narrower radar beam and better target separation. The real problem in plotting either manually or with MARPA is that small boats especially sailing boats do not maintain a constant heading and yaw from side to side. I suspect on a fast powerboat the heading is much steadier, plus the speed can be much closer to the speed of the target vessel, even faster than some both of which would aid MARPA.
TonyS
23 Feb 2003
Southampton, UK
Re: How about this
The problem as someone else has mentioned is multiple ships. Particlularly when they are from the same approx direction but greatly different speeds. But here MARPA shows quickly what is the best solution
Tony
jimi
19 Dec 2001
St Neots
Think that what Parahandy is saying is that having the diplay set to North up eliminates any yaw or helm wandering issues. I certainly understand although in practice I think I'd stick to head up on the basis that I find it easier to visualise whats happening around me. I tend to switch between 12 miles and 6 miles when crossing as I want to start to take action to cross behind when about 5 miles away. In poor vis. I try and pass as close to the stern as possible.
Mudplugger
12 Jun 2003
East Coast/ North Sea
Re: Well said
Parahandy's point about the speed differential, rather puts it all into perspective...
if crossing Southern N. Sea ( Harwich/ Ostend) for eg. Lanes are 5m wide,with seperation lane (chicken Strip) of about a mile. IF? vis is good, horizon is probably @ 6m in reasonable sea conditions,(3/4 the radar range?) in the time it takes to cross the lane @ 7knots.The commercial vessel will have travelled about 18m, if there is a group of them in staggered formation, one could have a worst case scenario of having to pick your way thru at least half a dozen, in the 40 mins of the crossing. To be fair it is not unknown for the Rectal Pucker Factor to scale new heights!, it all depends on how much traffic....But we are out there for pleasure?, they're doing it for a living, so personally attempt to stay well out of the way.
Tony W
<hr width=100% size=1>Tony W.
Robin
30 May 2001
Nice idea but in practice you need a gyro compass and fast computing, OK on ships but on our size of boat and within affordable electronics is very unlikely (yet!).
Like you we work head up, but watch on 6ml range with an occasional look farther out at 12mls range to see what is coming up next. I don't agree with Tony re switching ranges every few minutes, that gives no time for either electronic or manual plotting to come up with meaningful answers. The fact that MARPA gives a 'solution' electronically after a few minutes doesn't mean it is a correct solution.
tome
28 Mar 2002
kprick
www.google.co.uk
You don't need a gyro, but you do need a fast and stable compass. Heading dynamics on yachts in a seaway can exceed 20 deg/sec and it takes roughly 2 secs to do a radar sweep. Typical beamwidths are 5 degs on radomes.
Open arrays are much better at discrimination but are heavier and much more power hungry, especially in windy conditions.
This means that it's impossible to stabilise the display with much less than 10Hz output from the compass. One of the most stable compass I've found so far is a Honeywell model costing about £500, which gives consistent headings on pitch and roll angles up to 40 deg. I haven't yet tried it on radar, but intend to. Many of the fluxgate compasses give quite large heeling and pitch errors.
For the most stable picture, North-up or course-up are best. Heading-up is the least stable.
Personally, I use our radar on 4M range for collision avoidance and rarely change except for occasional look-sees. We don't have a stabilised display (it's an elderly Foruno). It's at the chart table, but I can watch it from the cockpit through a small hatch if I have the autopilot on. The EBL is the tool I mostly use.
You cannot use radar by glancing at it occasionally. You need to study it over several sweeps to build a picture.
Professional ARPA is only specified to 1.8M CPA accuracy over 1 minute, and 0.7M over 3 in a crossing situation. This is with large open-array antennas and better than 1 deg discrimination. MARPA will of course be less than this so you need to be very conservative when using it. Having said that, it's a great tool and I'm going for this when the current system dies (which I don't think is far off!).
Robin
30 May 2001
We had a really good 'old' Furuno on our last boat, large and very clear CRT screen and much better than the current Raymarine LCD one. Ours is at the chart table, next to a 10" plotter and with a 2nd autopilot control head as well. We also have a multi which I use to set and check we are 'on course' when using the EBLs. The PBO article and Parahandy refer to the mathematics of the errors +/- and the effect they may have, and that assumes that the scanner has been aligned to see the correct heading too!
Very interesting to see the quoted accuracy of full commercial ARPA, so MARPA has to be used with some caution.
webcraft
8 Jul 2001
Cyberspace
www.bluemoment.com
I don't understand a word of this thread . . . am I doomed?
- Nick
<hr width=100% size=1><font size=1><A target="_blank" HREF=http://www.bluemoment.com>http://www.bluemoment.com</A></font size=1>
ashanta
28 Apr 2003
Re: How about this
If you stop everything becomes relative on the radar screen. A yacht is slow, stopping is not a problem if you are unsure of others direction and the picture is as is!
I agree with Ken, If you are to avoid collision make a clear move into safe water and resume your original track once clear.
tome
28 Mar 2002
kprick
www.google.co.uk
Re: How about this
Stopping is good, but only if you have a stabilised display. If (like me) not, you'll render the radar picture useless.
You cannot maintain a heading when stopped. The more speed you have, the better your radar picture wil be.
