LittleSister
What would be the effect on a yacht engine gearbox of putting in ATF instead of the engine lube oil it should be?
The background to this is I had a problem with the gearbox (BW7 on a Bukh 36) of a then new to me boat. It would go in and out of gear easily when engine stopped, into gear easily when engine running, but very stiff to get out of gear (both forward and reverse) when engine running (i.e. when prop and gearbox loaded), such that frequently it would take so much force to pull it out of gear I'd shoot past neutral and crash into the opposite gear with a horrible crunch, and then have the same problem getting out of that new gear. (All rather stressful in a crowded marina!)
I'd checked the gear lube level was correct, and initially thought (I can't remember why) the problem was something to do with the controls, the cables, or the contraption that combines/changes over the two control stations (wheelhouse and cockpit)l. I tweaked those and changed one of the cables with no significant effect. Having studied the gearbox drawings and asked on here, I came to the conclusion it was beyond me, I would have to change the gearbox, and bought a second hand one.
The boat has since been out of the water for several years due to life calamities, and coming back now to recommission it I drained the oil from the gearbox in preparation for removing and replacing it. The oil I extracted is dark brown, but has a distinctly red hue to it. I would have thought that I would have changed the gearbox oil when I had the boat in commission, but it was a bit of a fraught time for me, I can't remember actually doing so, and struggle to imagine that the engine oil I would have used would have darkened that much given the relatively few miles I was able to do in it (though it has stood unused for several years since).
If the previous owner had mistakenly put ATF in the gearbox, instead of engine lube oil, could that be the cause of my problem getting out of gear?
