Atalanta of Chester/Hanne Knutsen trial
JumbleDuck
8 Aug 2013
SW Scotland
JumbleDuck
8 Aug 2013
SW Scotland
He must have a pretty good story, otherwise why is he taking such a high risk in going to court?
That is precisely the same argument as "The prosecution must be pretty sure of their case, otherwise why would they go to court". If it turns out that a 150,000 tonne tanker turned so fast that a racing yacht could not keep out of its way, I shall have complete sympathy, of course.
l'escargot
Isle of Wight / Jersey
toad_oftoadhall
28 Jun 2007
Med/Scotland/South Coast
I think an immediate 90 degree turn to starboard in response to the tankers sound signal that he was intending to turn to starboard could be seen as "clear and early evasive action".
I don't. I think Atlanta should have been miles out of the way long before that. I don't practice what I preach, but that's what I think. If a ship makes an unexpected sharp turn and wipes me out with his stern I'll take that as being my fault, even if the rules say otherwise. I should have given it a lot more space.
...but the court case is nothing to do with prudence or otherwise. It's about three very specific questions.
JumbleDuck
8 Aug 2013
SW Scotland
I think you will find that is what they were trying to do, I doubt very much that they decided to stay where they were and get run down...
Indeed. But perhaps in the excitement of racing they thought they could get away with nipping across the Kanne Knutsen's bow. I wonder if they would have been prosecuted if the two boats had missed each other by ten feet?
toad_oftoadhall
28 Jun 2007
I very much doubt that a collision alone is proof of an inadequate look out and JumbleDuck has failed to cite a case where it has been.
You didn't ask, sweetie. Here's just the first UK case Google turned up:
http://www.dft.gov.uk/mca/mcga07-ho...s-releases.htm?id=632CCB891694D0E2&m=2&y=2012
I think there is a bit more there than collision alone to indicate that he wasn't keeping a lookout...
Yup.
JumbleDuck
8 Aug 2013
SW Scotland
Atlanta failing to use her engine might be their downfall in the court case. It may have made *** all difference, but it doesn't help the defence.
I saw a claim somewhere that the collision situation was apparent to the pilots on the HK four or five minutes before the crunch. If that's the case, I wonder why neither boat took evasive action.
oldvarnish
15 Jul 2005
Strict Liability Contempt under the Contempt of Court Act 1981
The strict liability rule may render the publication a contempt regardless of any intent to interfere with the course of justice in the proceedings. Refer to The Law, earlier in this guidance, applies:
to publications (including broadcasts , websites and other online or text-based communication) addressed to the public at large or any section of the public;
(From the CPS website)
JumbleDuck
8 Aug 2013
SW Scotland
You're offering a plausible scenario where Atlanta might have seen the HK?
A short while ago you were arguing that a collision between two vessels proved beyond reasonable doubt no lookout was being kept.
Explain.
There is a different between "seeing" and "maintaining a proper look out for" (in your own words, an appropriate watch). The former only implies that you know the other thing is there; the latter implies that you look carefully enough to determine the other thing's likely behaviour.
If attempting to nip under the bow of a large ship, one should be keeping a sufficiently good lookout to know if it's not working and take alternative action. As indeed one should in any stand on / give way situation.
toad_oftoadhall
28 Jun 2007
There is a different between "seeing" and "maintaining a proper look out for".
Cite. (and can you actually read your source this time rather that posting something irrelevant.)
The rules simply say your lookout must be good enough: "so as to make a full appraisal of the situation and of the risk of collision".
If your actions based on that appraisal are wrong you haven't failed to keep a lookout, although you might have broken other rules.
fireball
15 Nov 2004
Do you think that's why we're not getting updates now?
Shame - because the court is open to the public, so why can a transcript not be published online?
Perhaps its because witnesses may read it and change their stories or juries may read it and be swayed by the arguments of the extracts?
JumbleDuck
8 Aug 2013
SW Scotland
Cite. (and can you actually read your source this time rather that posting something irrelevant to waste the forums time.)
I've already explained. But if you insist how about, ooh, shall we say ... the IRPCS?
5. Look-out
Every vessel shall at all times maintain a proper look-out by sight and hearing as well as by all available means appropriate in the prevailing circumstances and conditions so as to make a full appraisal of the situation and of the risk of collision.
Resolution
16 Feb 2006
I cannot see how the charge of failing to maintain a proper lookout can be made to stick - UNLESS in one of his statements to the MCA the skipper said something along the lines of "it came up on my blind side/never saw it until it hit me guv". Presumably the onus is on the prosecution to PROVE the charge.
