JumbleDuck
Or were they sailing away from the indicated path of the tanker when it changed direction again and headed towards them?
Even in which case perhaps "getting out of the damn way" would have been a sensible option?
Does it matter in relation to the "lookout" charge? I very much doubt that a collision alone is proof of an inadequate look out and JumbleDuck has failed to cite a case where it has been.
4 Worst of all his suit does not fit him - and what about that tie he wears?
He must have a pretty good story, otherwise why is he taking such a high risk in going to court?
You didn't ask, sweetie. Here's just the first UK case Google turned up:
http://www.dft.gov.uk/mca/mcga07-ho...s-releases.htm?id=632CCB891694D0E2&m=2&y=2012
I think an immediate 90 degree turn to starboard in response to the tankers sound signal that he was intending to turn to starboard could be seen as "clear and early evasive action".
I think you will find that is what they were trying to do, I doubt very much that they decided to stay where they were and get run down...
I think there is a bit more there than collision alone to indicate that he wasn't keeping a lookout...
Atlanta failing to use her engine might be their downfall in the court case. It may have made *** all difference, but it doesn't help the defence.
Yup.
But perhaps in the excitement of racing they thought they could get away with nipping across the Kanne Knutsen's bow.
Suggest you look at section 3.1.6 of the MAIB report.
You're offering a plausible scenario where Atlanta might have seen the HK?
A short while ago you were arguing that a collision between two vessels proved beyond reasonable doubt no lookout was being kept.
Explain.
There is a different between "seeing" and "maintaining a proper look out for".
Strict Liability Contempt under the Contempt of Court Act 1981
The strict liability rule may render the publication a contempt regardless of any intent to interfere with the course of justice in the proceedings. Refer to The Law, earlier in this guidance, applies:
to publications (including broadcasts , websites and other online or text-based communication) addressed to the public at large or any section of the public;
(From the CPS website)
Cite. (and can you actually read your source this time rather that posting something irrelevant to waste the forums time.)
