Copious
Does anybody have any recommendations/info on someone/company who does this?
Many thanks,
Copious
Many thanks,
Copious
The question hasto be asked, why does it need to be re gassed!Does anybody have any recommendations/info on someone/company who does this?
Many thanks,
Copious
Indicative of lo gas, yes, but where did it go or get out. If you just refill it it will escape again. Usual suspects are defrosting with a pointed knife or leaking O ringsin the quick disconnects. Whichever, the leak hasto be fixed firstBeneteau381: Half of the chiller plate is frosty whilst the other is not. As I understand it this is indicative of low/incorrect refrigerant pressure. Let me know if you think otherwise.
Bobc. The guy who I was directed to by the Arzal marina office has recently retired but I now have a lead to a commercial refrigeration outfit nearby who have apparently done this.
Watch this space.
Be wary, if regassing charges are anything like they are in UK it may be cheaper to buy a new evaporator plate
Had my fridge regassed in Brittany last year.
Cost: 85 Euro.
It's been as good as gold since.
If you do not find it, then you might try doing it by yourself there are kits available.Does anybody have any recommendations/info on someone/company who does this?
Many thanks,
Copious
That's fine if you know the gas pressure required (normally on a sticker/info plate ) and the fitting to connect the gas to.If you do not find it, then you might try doing it by yourself there are kits available.
I had the same symptoms, the top of the plate did not freeze, I added gas until the first few cm of the return pipe began to freeze. Disclaimer: I have a very old compressor which I would not mind replacing, so by curiosity I tried these "Duracool" gas cans knowing I might have to throw everything away, well a couple of years passed and the compressor still works very well, we'll see how long it lasts.
Surely if you replace the evaporator plate without the assistance of a fridge engineer, the waste gas will burn a hole in the ozone layer?Be wary, if regassing charges are anything like they are in UK it may be cheaper to buy a new evaporator plate
