oldgit
Pitch black. Got to squeeze in between two boats ...and you know the owners are both on board and probably asleep.
The bowthruster vital to finish the job without drama has decided to conk out at precisely that moment.
A quick check in the morning suggests only the controller on the fly is at fault, operates in one direction but of course not in the direction you so desperately needed.
A quick internet search results in
A new controller £200 +
A new joystick. £110 +
or
A quick dismantle, clean microswitch contacts with emery and splash of switch cleaner.
The less hamfisted and not using a kitchen knife might result in a neater splitting of the case but in slapped back together OK.
The joystick gaitor( £10.00 ) had perished allowing water to get in.
Really needs a replacement micro switch but search on the interweb produces nothing even close
Pin needs to be in centre of switch all switches appear to have the pin at the extreme end of unit.
For the interested the switch was made in Italy by CEMA.
or
