Arghh...Ow Much....
DipperToo
7 Jan 2005
Now a formal berth at Northney
I seem to recall a couple of years ago a couple bought a twin rudder southerly and had all sorts of issues berthing -it disappeared from our marina so I never found out if was a general issue with southerly or just a steep learning curve.
Steep learning curve. Especially on the Southerly 110 as the prop is virtually level with the twin rudders so absolutely no steerage with prop wash at all.
15 years ago when I got the boat, a half day with a twin rudder expert was invaluable. the hardest part was forgetting all you knew about holding alongside with a midships line and helm hard over - it just doesn't work. The 2 main lessons learnt were go intro a tight turn with some speed, helm hard over then engine into reverse halfway through the turn. Second, in confined spaces it is easier to reverse and use the bow thruster as a rudder!
DownWest
25 Dec 2007
S.W. France
So, Vetus bowthruster on a 60 odd ft unusual yacht, designed by the bloke that did Port Grimauld next to St Trop.
Vetus said, you don't have a problem with the switch, they don't fail. So I found the micro switches on the net and rebuilt it. Not too impressed with Vetus.
oldgit
6 Nov 2001
Medway
...about 10 mins to remove controller, dismantle, click both microswitches into position ,reassemble and glob of silcone sealer to reseal slightly perished gaitor on joystick.
....and nothing else damaged, broken or mysteriously becoming inoperative during repair.
