Araldite, Uses
It is very good for bedding shaft bearings, the 2011 precision, blue/white tube is ideal as it has a low melting/softening temperature but it is very sticky. It can be thickened with Talc and used as a bedding or if it is warm and it starts to run. We also recommend it for fitting underwater bolts/parts to prevent them loosening by vibration. Rather than a locktite/thread lock.
So not good for temperatures greater than 40C which your brakes will be.
It also provided a "temporary" fix to a corroded water jacket/cylinder head joint in a ancient Hillman imp.Was still OK when car was sold a few years later.
A long time ago in a different aquatic life, it was well understood that a mechanic with a hammer, some araldite and duct tape could repair just about anything.
I dripped warm Araldite onto a leak on the heater matrix of my ancient (t)rusty Peugeot 204 in the 1970s ( the matrix was a pig to remove and I had no money for a new one anyway). It lasted the rest of the car's life, but under any high heat of any consequence Araldite just falls to bits, so deffo not brake linings. In fact I'm now wondering how they do bond brake linings on to shoes?
Tim
Just had bad experiences with the genuine araldite recently-doesnt seem to be as effective.
Some of the best was from "The Wharehouse" over in NZ-combine "Go outdoors" with Woolworths and BandQ and you have the Wharehouse.
