ChromeDome
Annual coolant change seems a bit excessive while every two years seems right .
It is, but I need 10-15 litres of coolant to run through the sea-water side every year, so it is either buying new to pour in and watch coming out of the exhaust or changing the engine coolant and re-use the drained amount by running it through the strainers.
Some years I've had "used but OK" coolant from a car in which case that is used for the sea-water side, and the boat engines are left as-is.
"OK" is when my refractometer shows sufficient antifreeze properties.
