billyfish
How long does antifreeze last ? Mines 2 years old. Should I renew? I know it was a annual job but I'm sure I read it could go longer now.
If you are just concerned about it's antifreeze qualities then just extract a small amount (dip small tube into filler, finger over the top, lift out. Repeat until you have an egg-cup amount) then put it in the freezer at home to see if it works at -18C. What you can't easily test for is the health of the corrosion inhibitors, for that you can only be guided by the coolant manufacturer's replacement interval.How long does antifreeze last ? Mines 2 years old. Should I renew? I know it was a annual job but I'm sure I read it could go longer now.
Not that Beta are at all helpful here. I tried to flush my 2-year old Beta 35 this year. The coolant wouldn't come out of the drain tap, even after removing the tap and pumping.... Seems a long time for a boat, Especially as Beta- for instance- suggests that the heat exchanger be flushed annually.
I have a Beta 30, in one of my boats, so I assume it probably has the similar crank case. Fortunately, I had no problem draining the old fluid. I see that you have removed the tap assembly. Did not clearing the hole with a bent wire to clear the sludge work? Usually does.Not that Beta are at all helpful here. I tried to flush my 2-year old Beta 35 this year. The coolant wouldn't come out of the drain tap, even after removing the tap and pumping.
I rang Beta. "Ah yes, a known problem. Kubota fits too narrow a drain and it blocks. Try pumping it out from the heat exchanger." So, it's not Beta's fault, they only sell the engines, blame it on someone else. Pumping out from the heat exchanger can get only one-third of the coolant out. Similarly by opening the calorifier fittings.
In the end I emptied the heat exchanger, topped up with tap water, turned the engine over briefly, then repeated this half a dozen times to help flush out the old coolant. On the final pass I topped up with concentrated antifreeze rather than water. A laborious and unsatisfactory solution (and I don't like using tap water in the engine). Any other ideas much appreciated!
Not that Beta are at all helpful here. I tried to flush my 2-year old Beta 35 this year. The coolant wouldn't come out of the drain tap, even after removing the tap and pumping. ...
...Any other ideas much appreciated!
Easiest is just to pull one of the hoses off, either just under the heat exchanger or by the oil filter. If you are careful you can catch most of the coolant.Not that Beta are at all helpful here. I tried to flush my 2-year old Beta 35 this year. The coolant wouldn't come out of the drain tap, even after removing the tap and pumping.
Possible contamination with sea water may be a problem. Not so much from the water but from chloride and corrosion point of view.Happened to watch an old Wheeler Dealers yesterday during which they they replaced the antifreeze in an old Triumph with a non-water based alternative that ‘would never need changing’. Is similar antifreeze available for marine engines and is it ever used….? Just curious.
This has been around for ~ 25 years without gaining serious traction. I've tested samples. Without going into the engineering in depth, ask yourself why it is not factory fill on Mercedes etc. Suffice to say there are disadvantageous and the the advantages are overstated.Happened to watch an old Wheeler Dealers yesterday during which they they replaced the antifreeze in an old Triumph with a non-water based alternative that ‘would never need changing’. Is similar antifreeze available for marine engines and is it ever used….? Just curious.
I know , so many types now...use to be just antifreeze mostly blue.It's a bit like engine oil.
Check the manual for coolant/type requirements.
Then decide on standard or LongLife version (any brand that meets or exceeds reqs.)
Dilute (plain water) as indicated on the label on the can and fill the engine.
I change annually because I collect the drained amount and use it for winter heating of the seawater side.
To me, the age of the fluid is more important than the engine hours because the properties "wear off".
Note: Despite popular belief, colour is not a unique identifier of type
I may be wrong but think the antifreeze part is long lasting and the corrosion inhibitor part is less long lived.
Annual coolant change seems a bit excessive while every two years seems right .
I see a lot of rusty coloured stained header tanks on pictures of boats advertised for sale which suggests people are prone to leaving it too long.
