zikzik
Yes. Its been well maintained Blusox.
All depends on the price versus your risk. When I bought mine i gave the boat a good going over, decided on not getting a boat survey and the highest risk was an engine/drive problem so I paid a mechanic who had a lot of experience of the specific VP engine to survey the engine and drive, including a compression check. He found a few problems and the seller agreed to pay the mechanic's bill to fix everything.Hi. I’m moving to the dark side and have put a deposit on an Antares 760. I’ve gathered a lot of info now on these boats, And the seller is very well known to my current broker.
I’m trying to decide if I should get it surveyed. I’ve watched the survey of my current sailing boat, and wonder if one would uncover anything the seller doesn't know about his boat or just generate a long list of minors and a big bill!
I can see you guys know these boats well. What do you think?
Given your lack of experience with these boats i would suggest that you get a survey.Thanks guys. Thats good info.
The boat has a good service and maintenance history, but a bit of cosmetic work to do. So it will come out of the water for that as soon as I get it back to my berth. Where everything can be done.
I just need to balance any possible discovery, and its cost, before or after I take delivery.
Ah yes. Insurance. I’ll check that.Given your lack of experience with these boats i would suggest that you get a survey.
You will find that many insurance companies will insist on a survey, so take that into account too.
Heating! As I use my boat all year.What have you added that you couldn't live without?
Congrats - if the engineer gives a pass for the engine in it's current condition and it's been regularly serviced that's good. Visually you can quickly assess the rest of the boat with a good look over, it's pretty clear when a boat has been neglected or looked after.Update. My current insurer GJW (20 years plus over three sailing boats) has confirmed that no survey is required by them until a/the boat is thirty years old.
So after lots of thought and various discussion, the conclusion is the money item that would hurt most is the engine. So I’m not going to get a survey, but I am planning to get an engineer to look first at the service records, then the engine etc.
I’m now sorting out a sea trial as well for my benefit but also to enable the seller, who obviously accepts the above, to create a contract between us (the deposit is on trust as the seller is known to my selling broker for many years, and was done in case my buyer pulled out after a survey. He didn’t.
Time to start bedtime reading the paperwork he’s got!
Assuming all goes well, I’ll be able to complete in mid January and take delivery as soon as my yacht is out of her berth at the end of January. Then start looking at what I want to do to it….
What do you wish you had?
Exciting innit! The best and worst day of boat ownership approaching again!!
Yes, the legs are "yacht legs", Beneteau offered them as an option from new, mine was never fitted with them, but the additional GRP layup at the mounting points is fitted as standard although access to that reinforced mounting point on the inside is extremely limited. Beneteau show the location of the mountings in the manual. The 760 has a draft of 1m, not sure how you would find a boat with offshore capability with less. I have fitted an autopilot and think there are postings about it in this forum somewhere. It works very well. Edit: see post #88 in this threadI have seen one advertised with beaching legs. Are these similar to yacht legs? I.e bolted, or located on studs on each hull and roped fore and aft to keep them upright?
The 760’s draft is the only thing not ideal for me, as we like a bit of pottering and parking within Poole harbour. I like the alternative of a flattish hull and outboard power much less though!
I’m used to autopilot on my current yacht. I’ll miss that on longer journeys a lot. I’ll look into what might work once the primary jobs are done. I also like the look of flooring in the cockpit. Thats just a cosmetic of course. But nice. I’m used to a lot of wood!!
