anodes
EASLOOP
17 Dec 2001
The Medway, Kent, UK
What devices are available to connect the rotating s/s prop shaft to the boat's hull anode (wooden hull). I can do the engine block of course but that is not spinning!?
Any ideas would be most welcome
rgds
John
ccscott49
7 Sep 2001
I have seen a little rotating sleeve, with a copper "brush" on it, which makes a connection between shaft and anode, but not sure who makes it, halyard?
pvb
UK East Coast
Electro Eliminator...
The most common device for this is called the Electro Eliminator, and it's available from places like <A target="_blank" HREF=http://www.asap-supplies.com>ASAP Supplies</A>. I've never quite understood why people fit these, because unless there's an insulated flexible drive between gearbox and shaft, the propshaft is already electrically connected to the engine. I think some people use the Electro Eliminator to overcome electrical interference problems. If cathodic protection is the aim, it would seem that a shaft anode or a prop nut anode would do a better job at much less cost.
Bodach na mara
21 Aug 2002
Western Scotland
The reason an "Electro-eliminator" is used is the resistance across the gears. I checked for continuity between anode and prop and found it fairly low on my boat, but on another boat it was highter and there was no flexible coupling. I cannot use a shaft anode myself as there is no room between prop and stern bearing.
<hr width=100% size=1>Ken Johnson
EASLOOP
17 Dec 2001
Thanks chaps. I feel certain that there will be a reasonable contact between engine block and shaft but I like the sound of the copper brush. I will look out for same.
best wishes
John
maxi
8 Nov 2002
Hampshire
Re: Electro Eliminator...
As ever, pvb makes a good point, however, a word of caution regarding shaft anodes and prop-nut-anodes. Anodes are effective in relation to their mass, therefore if there is a lot of zinc loss on a small anode it becomes rapidly less and less effective.
Shaft and prop-nut anodes are usually very much on the small side, especially the latter & whilst they undoubtedly work they also need to be very regularly renewed.
It may be more economic and effective to fit a decent sized anode, properly bonded, and which will last several seasons unattended.
As for your spinning shaft, try adapting one of the brushes out of a dead Black & Decker or even a piece of spring metal bearing onto the shaft will give you your connection, simply and cheaply.
