maby
An NMEA repeater app is exactly what is required. This needs some low cost hardware to link to the nmea network without having to use a PC. The only thing I have found so far is the digital yacht wifi converter but this is very expensive.
It's a non-trivial task to build such a thing - I'm working on something a lot simpler at the moment and it is going to cost well on the way to £100 in parts alone. OK - you could do it cheaper building from scratch, but it's hard work soldering up modern surface mount components. I'm using a couple of modules from Arduino which cost about £30 each, then I'm going to need a WiFi bridge that will be another £30. Add a small case and a few other supporting components and we are up to the £100. How much is that Digital Yacht thing? I suspect you would have to value your time very cheaply to justify trying to build one yourself!
