Andriod Phone Apps
An NMEA repeater app is exactly what is required. This needs some low cost hardware to link to the nmea network without having to use a PC. The only thing I have found so far is the digital yacht wifi converter but this is very expensive.
It's a non-trivial task to build such a thing - I'm working on something a lot simpler at the moment and it is going to cost well on the way to £100 in parts alone. OK - you could do it cheaper building from scratch, but it's hard work soldering up modern surface mount components. I'm using a couple of modules from Arduino which cost about £30 each, then I'm going to need a WiFi bridge that will be another £30. Add a small case and a few other supporting components and we are up to the £100. How much is that Digital Yacht thing? I suspect you would have to value your time very cheaply to justify trying to build one yourself!
can the tacktick wireless system be amended to output over wifi n/g/b or bluetooth rather than its proprietry wireless bandwidth?
I know tacktick nmea transmitters can be had on ebay for around £100 - surely the wifi/bluetooth transmitters are only a few pounds?
This may be a little circular :-). I think Hans's reply was to my post #35 asking about android nmea display apps to test the multiplexer/wifi thingy I built from a raspberry pi and posted about here. Costs (see the link) rather less than most of the alternatives. The multiplexer software (works on pi, but also on a mac, linux or freebsd laptop) is kplex which I've sadly only had feedback on from one person so far. I think distributing it in source format and not having a gui puts most people off so in the coming week I'll look at putting a pi deb together and whilst I'm normally gui-averse I'll look at knocking a GUI together if that's actually the only thing putting people off.
Meantime nmea display apps may be the metaphorical buses of android. Wait ages for one to come along..well I got bored waiting and started looking into writing my own...
If I get some time after new year I'll see about some kind of howto for the pi access point with nmea multiplexing for those not super familiar with Linux.
The Tacktick NMEA transmitters solve a different problem - they interface Tacktick wireless instruments with NMEA0183 networks - not Bluetooth or WiFi frequencies and a proprietary protocol. I repaired one recently and they are full of custom LSI components - not suitable for modification.
If anyone wants to tackle it, I think Arduino modules are the way to go. A processor board with loads of digital and analogue ports costs about £30 and an Ethernet module is another £30. There is a WiFi module for a little more and Bluetooth is also available. You can download the development software free and you just need a standard PC to program the card.
Has anyone get details of the standard NMEA over Ethernet protocol? I don't think I've ever seen it documented - might have a go sometime if I can get the protocol documentation, but it would not be an economical project - it would take a lot more than £125 worth of my time!
Two aps I'd love to see:
1) a simple compass ap that just shows when I deviate from the set course with a simple Red or Green colour. This would be great instead of watching a compass when out at sea. For example, if I am 5 deg off course it would show a small red or green dot. if 10 deg off course it shows a larger dot. If 15 deg off course the dot starts flashing, etc. Watching the numbers on a compass is impossible at 3 in the morning. This would make it much easier.
2) a REAL AIS that plugs into my hand held VHF radio. Not just the android AIS units that tap into the local web access, but a real AIS that I can use at sea without internet access. My android already has a real GPS on it, so I'd think that a real AIS would be relatively simple, even if it doesn't use actual charts but just shows ships around me so that I can call them by name.
Covered in this thread. Essentially it's just nmea-0183...but bunged into IP: either a tcp stream or a UDP packet. I'm not aware that there's any sort of documented "protocol". In the beta version of OpenCPN all the networking seems to be done behind wxSocket* objects which abstract UDP away into a datastream so the question of one vs. multiple packets doesn't arise.
Not sure I would want to take my tablet into the cockpit at 3am, but your compass application should not be too difficult. If I ever get round to hacking it together, are you Android or Apple?
There are cheaper solutions!
I'm currently using two approaches:
1. BlueTooth:
http://dx.com/p/jy-mcu-arduino-bluetooth-wireless-serial-port-module-104299
You can connect with one device to it e.g. an Android phone, the thing is very cheap!
2. A wifi module: e.g. RN-171 (Farnell) has several modes, one of it is TCP.
I have been using it in a wifi network, so with an access point in it. It is also possible to use it as an ad-hoc open network, you don't need an ap in that case, you just connect it directly with your phone, but you are less flexible.
regards
Hans Fix
