vyv_cox
Two anchors in line gives greater holding power but you do have the swinging issue. Cheers, Andrew
I have been trying to organise testing of this one, which I strongly doubt. In no area of engineering that I know of does doubling up the holding result in distributing the load evenly on both parts. Screw threads for example, where 90% of the load is taken on the first thread and most of the rest on the second. High pressure gas seals, which have been a large part of my work for many years, do nothing like what the compressor industry think, but again almost all the pressure is taken on the first ring pair. Some packings have 12 ring pairs, all the others just sitting there with no pressure acting upon them.
So for tandem anchors, I shall not be surprised to find that either one or the other does nothing while the other does everything. I will be amazed if there is any sharing of the load between them. With anchors laid at 90 degrees of course there is no doubt: the load alternates between the two, never pulling both at once.
