MathiasW
So it took one century: conservative who? sailors?![]()
Hmm, it took a century to convince less than half of the community, I'd say...
The maximal holding power of an anchor increases roughly only linearly with its weight, whilst the wind load increases quadratically with wind speed. This implies that increasing anchor size is not an efficient way to be able to withstand larger wind speeds. Example: When my maximal holding power just allows me to tolerate a wind speed of 30 kn, then an anchor increased by 10% in weight will up this number to only 31.5 kn.
The biggest advantage an increased anchor can offer is when you cannot pay out as much chain as you want. Here a 10% increase in holding power can very efficiently offset the negative effect of a larger pulling angle at the anchor shaft, and thus allow for a substantially reduced chain length before the anchor starts to drag. In tight spaces, this can really make a difference.
Cheers, Mathias
www.anchorchaincalculator.com
There are many practical benefits for what is a small (typically less than 10%) increase in total ground tackle weight.
In extreme conditions when anchors are likely to drag the chain will be off the bottom in shallow water so weight is of little use there. We were sitting through several squalls of 44/45kts on 4:1 scope and a long snubber over Christmas in 7m of water with no concern about dragging with a 30kg Spade. It was well dug in when we came to lift it.As you correctly point out, a 10% increase in anchor weight is too small a difference to provide much practical benefit in protecting against increased wind strengths, but even this small difference will help reduce the scope required.
Some anchor manufacturers produce tables showing the relationship between the maximum available holding power with a varying scope. If we do the maths, a 10% increase in anchor weight (assuming the same anchor design and material) would mean that, for example, the 10% heavier anchor would have approximately the same holding power at 5:1 as the smaller anchor at 6:1 . These are theoretical predictions, but help quantify the difference you may expect.
Even for this very small increase in anchor weight there are practical gains.
Anchor sizing is always complex, but I believe the best anchor sizing philosophy for most cruising boats is to use the largest anchor that can be comfortably managed (by both boat and crew). Applying this philosophy, at least as a starting point, will usually result in more than a 10% increase in anchor weight.
My post # 49 (shown below) may have started the discussion on the effects of a very small 10% increase in anchor weight:
In this post I was not referring to the anchor weight, but to the total ground tackle weight, which includes both the anchor and chain weight.
Agreed.In extreme conditions when anchors are likely to drag the chain will be off the bottom in shallow water so weight is of little use there.
Our chain locker is very low down and some distance back from the bow. A heavy anchor would have disproportionate effect on weight over the bow compared to a plumb bow modern yacht ( except where the modern boat has a sticky out bow roller due to the plumb bow) that has its chain locker well forward. Even on our heavy boat we do notice the difference keeping weight out of the ends when bashing to weather. Friends who have the 45ft version of our 44ft hull carry way to much weight in our opinion. They are at least 4" deeper in the water than us. They carry far more chain and a 40kg anchor. They have had no end of trouble with mast standing rigging. Lots of strand failures. I wonder how much of it is due to an overloaded boat stressing the rig when beating to windward.Agreed.
My point about weight was that for most cruising boats the total ground tackle weight only increases slightly in percentage terms even if the anchor weight is increased substantially.
For example a yacht with 80m of 10mm chain and a 20kg anchor has a total ground tackle weight of around 184 kg (chain weight) + 20 kg (anchor weight) =204 kg. If the anchor size is increased to 30kg the maximum holding ability increases around 50% (assuming the same anchor design and construction material) but the total weight in the gear required to anchor only rises from 204kg to 214 kg or around 5%.
The percentage rise will be greater for boats with less chain, but even here choosing a larger anchor adds practical benefits (such as the ability to utilise anchorages with poorer holding ground and the ability to use less scope for the same holding power) for only a small relative increase in weight.
Make sure you do not select an anchor larger than one that can still be comfortably managed. The above example assumes the heavier anchor still fits this requirement.
What changes, at least for me, is the capacity of handling the anchor by hand: I can move 20kg of oddly shaped steel, 30kg I cannot.Increasing the size of the anchor from 20kg to 30kg
We don't carry anything heavy in our bow locker. It's a huge locker. I can easily lie down in it but it has empty fuel and water cans in the front part near the bow and fenders and ropes towards the rear. On long passages the 35kg outboard lives in the ensuite on the floor wedged with fenders. The dinghy is on deck. Sails for use on passage are moved from the sail locker under the front bunk to the saloon ( mizzen staysail, spinnaker, storm jib). The heavy ropes from the front locker move to the sail locker under the front bunk. All of this repositions weight out of the ends of the boat. The floor of the anchor chain locker is below the waterline and with are very angled bow, put this about 7 ft back from the anchor stored on the bow roller.Yes, it is a good point, the anchor weight is typically a little further forward and higher than the chain, but the difference in the distance from the centre of gravity is slight on most yachts. The (typically) much higher weight of the chain in relation to the anchor on cruising boats means that the chain weight is the major contibuter to the bow weight or moment of inertia.
For example the hypothetical boat in post #66 has 204kg in the bow as a result of their anchoring gear. Increasing the size of the anchor from 20kg to 30kg only increases this to 214kg. The fact that the extra 10kg is a little further forward from the centre of gravity than the majority of the chain weight is really a very minor difference.
It is always a puzzle why many cruising boats carry substantial supplies, spare parts, water, oil and often what is little more than junk well forward but are concerned about an extra 10kg in the anchor. I think it because the anchor is very visible where as the other weight (including the chain weight) is out of sight.
There are exceptions where the anchor weight is more significant than the chain weight such as Geem has described . This effect is even more pronounced in some catamarans that fit their anchor forward near the cross beam but keep their chain is much further back near the mast and close to the centre of gravity. If it is a high performance catamaran with fine and empty bows the extra 10kg may be significant. You can understand why the owners of these vessels may be concerned about minor changes to anchor weight . Fortunately these characteristics do not apply to most cruising boats.
For similar geometry anchors it is not usually a good assumption that the holding capacity will vary linearly with the weight of the anchor. It can generally be assumed that for geometrically similar anchors, holding capacity in mud or sand will scale with the area of the anchor, ie with the linear dimension scale factor squared. However, the weight will rise with the cube of the linear dimension scale factor. Hence if one works out the holding capacity as a multiple of the weight of the anchor, one will find that this reduces as the size of the anchor increases.The maximal holding power of an anchor increases roughly only linearly with its weight, whilst the wind load increases quadratically with wind speed. This implies that increasing anchor size is not an efficient way to be able to withstand larger wind speeds. Example: When my maximal holding power just allows me to tolerate a wind speed of 30 kn, then an anchor increased by 10% in weight will up this number to only 31.5 kn.
Cheers, Mathias
+1For similar geometry anchors it is not usually a good assumption that the holding capacity will vary linearly with the weight of the anchor. It can generally be assumed that for geometrically similar anchors, holding capacity in mud or sand will scale with the area of the anchor, ie with the linear dimension scale factor squared. However, the weight will rise with the cube of the linear dimension scale factor. Hence if one works out the holding capacity as a multiple of the weight of the anchor, one will find that this reduces as the size of the anchor increases.
I think anchor weight is an extremely poor measure, or rather it is a loosely connected second measure when it comes to anchor holding.
Wonder no moreI also wonder in an over sized anchor whilst might provide a larger fluke area, suffer because the vessel isn’t powerful enough or unable to generate sufficient rode load to get optimal burial.
Or not if its fouled a plastic bag, towel, tin can, kelp, etc. It happens to any size of anchor in and kind of ground. Big doesn't guarantee you better hold if you haven't got the engine grunt to set it, it's not ideal waiting for strong winds to see if it's set in my opinion.An anchor doesn't know what size of boat it's holding. It's ludicrous to say that a big anchor won't hold a small boat, because it's not "dug in". It'll soon dig in when the wind gets up.
I think we're all aware that a fouled anchor doesn't work. ? Do you never anchor under sail?Or not if its fouled a plastic bag, towel, tin can, kelp, etc. It happens to any size of anchor in and kind of ground. Big doesn't guarantee you better hold if you haven't got the engine grunt to set it, it's not ideal waiting for strong winds to see if it's set in my opinion.
I just made a quick check with Spade anchors weight/surface as stated on their site, an S100 having 1000 cm^2 of holding surface, etc.+1
supposing holding dependent on area, it increases more like a factor weight to power (2/3)
