TNLI
300 series stainless steel, which includes 302, 304, 316 and anything else that starts 3xx, is austenitic. The difference between them is compositional. It makes no difference, they cannot be strengthened by heat treatment. In every alloy I can think of, annealing results in the weakest form.
True, but some metals are annealed to improve the fatigue life, not the UTS figure of the metal. It's the sudden fatigure failures of far Eastern stainless that might even be below 302 that is the real danger with cheap copies, or packet swap scams that many major companies have suffered to their cost. Packet swap scams involve a person or persons in the parts depratment or shipping, opening up the boxes and swapping the contents for a cheap Chinese copy. They then sell the real item on Fleabay or do a returns deal with the Chinese company who made the junk copies.
Obviously you know far more than me about bad stainless than I do, and I made something of an error on using the word annealing rather than treatment, as that was what a learned USCG boat designer told me a few years ago about fatigue failures of Chinese rigging wire. The drum of 1 x19 316 wire looked like expensive Hasselfors wire with all the correct marking and labels. Even the associated paperwork was a perfect copy. It was used to re rig a number of local yachts, but started to strand at the terminals after only 3 months. All the yachts needed a full rig change.
What Is the Annealing Treatment for Austenitic Steels? (inoxmare.com)
Extract from link:
What is the annealing heat-treatment for stainless steels?
The process of annealing (intended for austenitic steels such as those stainless steel and duplex) is an heat-treatment for precipitation-hardening. This treatment is performed at high temperatures, usually > 1000°C. Indeed, it provides heat at a temperature between 1000 and 1100°. This ensures the annealing of the alloying elements inside of austenitic grains. Maintaining the temperature of heating should last the time required to ensure that this temperature reaches the steel piece heart. Only thanks to this stasis you can eliminate structural alterations that were caused by previous machining. Next, we expected a rapid cooling of the piece in air or water, just to prevent the precipitation of chromium that is usually between 450° and 850°.
They seem to think the production process of cheap stainless results in physical faults, (I presume that's what they mean by alterations), or scratches that concentrate surface stress. I can provide you with other links that use the word annealing in reference to improving the fatigue life, but I'm busy for the rest of the day, so can't do that until late this evening.
PS: I have sent a message to Inoxmare asking them about fatigue life, BUT there is a difference in defintion terms between what they call structural alterations from the production process, and normal fatigue life. So it might take a few Q & A's before I get a good answer, as it's the tiny cracks that can't be seen in new far Eastern stainless that is the issue. It's those cracks that can cause direct shear failures at very low torque, in addition to low fatigue life figues.
Back to replies to the OP, this is the last part of a reply from Peeves down under in Auz:
Confess I have not seen your original post, life is too short to sift though over 300 posts and 18 pages - so if you have defined your yacht - it lost in Forum mists.
I'd actually suggest you start a new thread - but this may invoke wrath
It's not too difficult to find out what you are supposed to be posting about, IT'S IN CAPITALS AT THE TOP OF EACH PAGE, and if you want to know more, just click on page 1. Just cos you can't read a title, or click on the number 1, does not mean the OP should start a new thread.
