Neeves
for the life of me, a quick connector is the last thing I would use anywhere within an anchor rode. If you keep your anchor and chain/rope separately (like I do for my kedge) then at least have a conventional shackle ready and greased on the chain or anchor to join the two. If you want to gild the lily, have a piece of mousing wire ready too. That fitting in the picture is one of the last things I would use for my anchor.
I cannot see any reason not to use a rated shackle from a reputable supplier. If they are from a reputable supplier they are individually Proof Tested, that's to 2 times WLL. Failure of rated shackles from reputable suppliers are simply not reported - suggesting they do not fail. Shackles are simple and simple to use. You need to secure the clevis (or shackle) pin Keep short lengths of mousing wire handy and in known places. Through the hole in the pin seems a good place. . If you like belt and braces - coat the pin with blue Loctite (it sets under water). If you anticipate not releasing the shackle pin - use red Loctite (it also sets under water) - but you may need a blow torch to release the adhesive.
The shackles of choice could be Crosby's G209A shackles - their 3/8th" shackle has a WLL of 2t. Campbell and Peerless in the US make shackles to a similar specification. Their UTS is 10t or 12t. Yoke in Taiwan also makes this quality and a couple of manufacturers in China - but for the life of me I cannot think how you would source. Crosby shackles are freely available in the UK, Tecni (I think based in Bristol). Our primary anchor is attached to the rode with one of the 3 aforementioned US shackles (and I have some of the Yoke and Chinese shackles - which I have tested) and each of our spare anchors has the shackle attached to the anchor. We have a spare rode stored in a milk crate, it also has an attached shackle. We also have a couple of spare shackles attached to the milk crate (shackles can be dropped over board). We do not carry any galvanised shackles of a lower quality - all our other shackles are stainless and cannot be mistaken for anchor shackles. Most shackles in hardware stores are not individually Proof Tested, but (if you are lucky) batch tested and will, for a 3/8th" shackle have a WLL of 1t. A good use for shackles from a hardware store would be for a small dog - but I would not use them on an anchor rode (reports of failure of shackles from nefarious sources do occur. For stg5 - why save money (your anchor and yacht are worth a bit more and hopefully your family are priceless).
I fail understand why there is any debate about how to join an anchor to chain.
Sorry but Thinwater's suggestion has simply too many components holding the device together which are not tested for side loading. Crosby, Peerless, Campbell etc shackles are tested for side loading and lose 50% or strength when loaded at 90 degrees - but as a 8mm G30 chain (a nice match for a 3/8th" shackle) has a WLL of 750kg then these shackles are still stronger than the chain (even if side loaded)
Jonathan
