scruff
Hi,
I'm needing to replace my anchor chain rode this winter; new boat (to me) has 5m chain and about 20m of blue poly (floating!) anchor rode.
This, obviously is not sufficient.
For the avoidance of starting an anchor debate, the pick on the end is irrelevant.
The boat; a Folksong does not have a hawse pipe so all the rode will be in the bow locker. As such, weight is a bit of an issue so unable to go for full chain.
I have looked at various sites and it looks like I could go for either 6mm or 8mm chain. For the same weight overall (and cost) I could have;
i) 50m of 6mm chain which weighs in at 40kg
ii) 30m of 8mm chain which is near as damnit 40kgs again.
Spliced on to the chain will be x meters of rope to make up the suitable length required for the west coast. It is quite likely that I will find myself anchoring in 10m depths so a long rode will be required and often swinging room is not an issue.
So my question is, what is more effective; a longer catenary curve with a lower p/m weight or a shorter catenary curve with a higher p/m weight?
Your thoughts please?
Many thanks,
Scruff.
Many thanks,
Scruff.
